centering rim
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
centering rim
25 Nov 2006 12:55
#94821
I just got a ZRX12 rear end. It seems that the rim is not centered in the swing arm.It is off by 3/16". Is this normal ?should this be a concern?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: centering rim
25 Nov 2006 14:46
#94831
id check to see if swingarm is straight 1st,then i would make new spacers to center up wheel once its on your bike.swingarm might be offset in frame for clearance issues on bike it came off of ;)
  • 77KZ650
  • 77KZ650's Avatar
Re: centering rim
25 Nov 2006 15:48
#94854
check to see if the center of the tire is under the center of your frame
Scott
07 MDP Rookie of the Year
  • mark1122
  • Keep twisting it
Re: centering rim
26 Nov 2006 05:04
#95004
I shimmed the wheel and did an alignment check(with string) with the front tire and it seams good now.I just cant understand why it would be offcenter?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mark1122
  • Keep twisting it
Re: centering rim
26 Nov 2006 16:18
#95137
It seams I will need a 1" offset sprocket on the front(this will require a suport), and I have clearance issuse with the frame.What do you think if i reduce the front offset by 3/8" and add it to the back sprocket in the oposite direction?this would give me 2 offset sprockets and eliminate the need for a front sprocket suport, while adding frame clearance.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: centering rim
26 Nov 2006 16:41
#95140
makes sense to me as long as its straight ;)
  • 77KZ650
  • 77KZ650's Avatar
Re: centering rim
26 Nov 2006 21:51
#95265
just remember offsetting the rear sprocket towards the tire can only go so far before it hits the tire;) make sure you have the room before you try anything. also, you probably wont find an offset rear sprocket. you could make one, but I think the easiest thing to do would be to machine down the sprocket carrier to move the stock sprocket in for the same effect;)
Scott
  • mark1122
  • Keep twisting it
Re: centering rim
09 Dec 2006 08:28
#98435
Ive decided to remove material from the rear hub (cush drive) to make it line up with the front sprocket.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
