cbr600 wheels and front end.
- DaytonaMC
- You keep for your collection, I know you like it.
24 Nov 2006 18:28
I have a 1990 cbr600hurricane that I want to rob the front fork and wheels off for my 77 1000ltd. The stem does not want to work is there any simple solution? I was just wondering if any of you have done this particular set up? Thanks
I must remove my skin.....
- rstnick
Re: cbr600 wheels and front end.
24 Nov 2006 18:47
Swap stems? Others have done it.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- DaytonaMC
24 Nov 2006 19:14
how do I swap the stem? Press it out?
- 77KZ650
24 Nov 2006 20:05
yes, use the kz stem in the cbr triple
Post edited by: 77KZ650, at: 2006/11/24 23:08
07 MDP Rookie of the Year
- rattler
24 Nov 2006 21:43
daytonamc check out this post the other day i made about what i had to do to swap front ends. it wont be exactly the same for ur front end but it would give you a general idea.
kzrider.com/component/option,com_joomlab...id,5/id,94709#94709/
- DaytonaMC
25 Nov 2006 06:50
- flht1997
25 Nov 2006 07:38
never looked at a CBR lower triple, but the KZ is probably welding in. grind the weld off, and press it out. get the cbr lower, i would guess it is bolted and pressed in. take it apart the cross you fingers they are the same size. if not you will need some machining or spacer made up. it is not too hard, i just pressed up a yz250 triple onto a kz400 stem.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- 77KZ650
25 Nov 2006 15:58
click here
should be helpful
- DaytonaMC
25 Nov 2006 17:02
yes that was helpful thanks.
If the kz stem has a smaller O.D. than the CBR stem do I need to use some sort of spacer in between?
- wireman
25 Nov 2006 17:13
if the kz stem is smaller id have it turned down on bottem then have a bushing machined to size and have it welded on that way the bushing is big enough to support it.
- DaytonaMC
25 Nov 2006 17:17
That's awesome. I really appreciate your help. I think you have given me what I need to make something look really cool. I will post pics of my progress.
- DaytonaMC
28 Nov 2006 11:48
now I got the stem problem taken care of but, now my rear axle is a bit smaller than my stock axle. do I just change the bearings on the cbr rim to fit my stock axle or what?
