brake help
  • wiredgeorge
  • wiredgeorge's Avatar Topic Author
brake help
21 Nov 2005 12:02
#9391
Bought a 79 KZ1000E1 (ST) this weekend. Brakes; especially the front and rear master cylinders are dry and nasty and probably frozen badly. I had some of the Zedder parts cross reference software but it doesn't work now that I "upgraded" to XP as all I get are Active-X errors.
Can someone look up the master cylinder and caliper part numbers and give me an update on what cross references?
Front -
43041-1020 CALIPER ASSY,L.H,FRON
43041-1021 CALIPER ASSY,R.H,FRON
43015-1032 CYLINDER ASSY,FRONT
Rear -
43041-1019 CALIPER ASSY,REAR
43015-1026 CYLINDER ASSY,REAR
Just want to know if I can use bits as a direct swap from other KZs of the era. Thanks!
  • OKC_Kent
  • OKC_Kent's Avatar
Re: brake help
21 Nov 2005 12:42
#9402
Here you go George.
Part # = 43041-1020
Part Description = CALIPER ASSEMBLY,FRONT,LH
Model Count = 2
Model Name Year Size Description Type
KZ1000-E1 79 1000 KZ1000 ST STREET
KZ1000-E2 80 1000 KZ1000 SHAFT STREET
Part # = 43041-1021
Part Description = CALIPER ASSEMBLY,FRONT,RH
Model Count = 2
Part # = 43015-1032
Part Description = CYLINDER ASSEMBLY,FRONT
Model Count = 12
KZ750-E1 80 750 750 STANDARD-4 STREET
KZ750-E2 81 750 750 STANDARD-4 STREET
KZ750-E3 82 750 750 STANDARD-4 STREET
KZ1000-J1 81 1000 KZ1000 J MODEL STREET
KZ1000-J2 82 1000 KZ1000 J MODEL STREET
KZ1100-A1 81 1100 1100 SHAFT TOURING
KZ1100-A2 82 1100 1100 SHAFT TOURING
KZ1100-A3 83 1100 1100 SHAFT TOURING
KZ1300-A1 79 1290 KZ1300 STANDARD STREET
KZ1300-A2 80 1290 KZ1300 STANDARD STREET
Part # = 43041-1019
Part Description = CALIPER ASSEMBLY,REAR
Model Count = 2
Part # = 43015-1026
Part Description = CYLINDER ASSEMBLY,REAR
Model Count = 2
By the way, my Zedder works on XP Home Edition. Can you find your encrypted e-mail he sent, and download another copy?
Cashion, OK
78 KZ650 B2 85,000+ miles
  • wiredgeorge
Re: brake help
21 Nov 2005 13:01
#9407
I worked with Steve Zedder for days trying to get the software to work. My version is the XP Pro and it must be a pirate version as a repair guy put it on... anyway, he sent several versions to me plus one non-encrypted/non-passworded version. It isn't a security issue it is an Active-X control issue... the issue is very common based on my search for the error on the internet and is seen in all types of conditions and with all types of software. Thanks for the look up!
