KZ650B1 steering stem removal...
- caffcruiser
15 Nov 2006 09:38
What's the best way you guys tackled this? It's for a swap obviously.... The Gixxers are pressed in.
- caffcruiser
- rstnick
Re: KZ650B1 steering stem removal...
15 Nov 2006 12:51
I've heard others have pressed out the stems, but how they go about doing so is beyond me. I've tried a search but have not come up with any real info.
Maybe this would help:
LINK
Post edited by: rstnick, at: 2006/11/15 15:56
LINK
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- 77KZ650
15 Nov 2006 13:23
Haha I just finished doing this, talk about timing. first you have to grind the ring of weld off of the bottom where the stem and triple clamp meet, next find something just a bit smller in diameter than the stem, (I used socket) and either beat it out with a BFH :laugh: or find some sort of press. I used an industrial hose crimper because thats what was available. (my father is into heavy woods machinery and does his own repairs)
Scott
Scott
07 MDP Rookie of the Year
- caffcruiser
15 Nov 2006 14:06
How much weld did you have to remove? I've taken off *maybe* 1/8" and it's still pretty solid. :laugh:
- 77KZ650
15 Nov 2006 14:26
I think close to 1/4, just go till you can see the line form then you're through the weld
- caffcruiser
15 Nov 2006 17:03
Got it.
Thanks.
I see now why they welded them... once that was ground away the damn thing nearly fell out! :ohmy: :laugh:
- 77KZ650
15 Nov 2006 18:59
they must not have been as accurate with them back then, mine was a bit stiff, I was glad I had some mehcanical help.
according to galaxian, my stem should press into the zx7 stem (cut off at the top of the triple) I tried it, and it didnt want to go(couldnt fit it in the hose crimper for some extra power either) so its sitting in a freezer till I try it again, hopefully it will shrink enough to make a difference, I know it does with other stuff with really tight tolerances....
- caffcruiser
16 Nov 2006 09:33
Heat the clamp when you do this too. Just use a propane torch and give it a few minutes of heat.
You'll be suprised how much of a difference it can make.
You just using a household freezer for the cooling?
- 77KZ650
18 Nov 2006 13:35
caffcruiser wrote:
yes, just the regular deep freeze. a few hrs have made impossible-to-fit pins on some of dads heavy equipment slide right in.Heat the clamp when you do this too. Just use a propane torch and give it a few minutes of heat.
I was allready planning on doing that
- rattler
19 Nov 2006 00:51
i had to remove quite a bit of weld off my bottom tripple alos to get the stem out of my 1000 tripples. i used a friends hydrolic press to push it out after the weld was taken down enough. i wouldnt just take for granted that pressing the stem into the new tripple is enough to hold. i have seen to may stand ups go bad when they hit the front wheel hard when coming down and actualy pull the steering stem out of the bottom tripple. wouldnt just trust a lock pin to hold either. just weld it like i did to be on the safe side.
