zx7 forks, triple/bar options?
  • 77KZ650
  • 77KZ650's Avatar Topic Author
15 Nov 2006 07:43
#92279
My 95 ZX7R forks arrived for my project, and I need an upper triple clamp(got the lower, and stem with the forks). Are there any that fit these forks that have the risers to mount normal bars (maybe a GPz or ZRX?)? I have clubmans, but was thinking about trying the super bike bars, but tht wont be an option if I get the standard clip-ons that go with these type of front ends. I guess I could always weld a set of mounts on later if I need to, but I thought I would check here first...
That being said, if Im stuck with clip-ons, anyone have a set and a triple that fits? :whistle:
thx
Scott
07 MDP Rookie of the Year
  • steell
  • steell's Avatar
Re: zx7 forks, triple/bar options?
15 Nov 2006 07:51
#92283
The upper clamps are generally aluminum and pretty simple for a machinist to make, so that may be an option.
  • 77KZ650
15 Nov 2006 07:59
#92285
that may be a good way to go, the lower one is aluminum as well, unlike our KZ's
  • 77KZ650
15 Nov 2006 08:09
#92286
the forks are 52mm if that helps, not sure about the other dimensions for the triple clamp
  • StreetfighterKz
  • StreetfighterKz's Avatar
15 Nov 2006 08:44
#92298
Here's one solution, although maybe a bit pricey. www.spieglerusa.com/cfm/sbk.cfm You should get a set of bars, longer S/S brake lines and maybe some other cables.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • 77KZ650
15 Nov 2006 14:14
#92370
a bit pricey lol, I paid 1/3 that for the forks, nice looking stuff though.
what about triples from other bikes? how would I go about figuring out which ones swap? I know that I can match part numbers, but what about triples that are just a bit different, but would still physically work?
stock looks like this:
  • 77KZ650
15 Nov 2006 14:17
#92373
now how can I tell if this would work too?
from an 01 zx12r...
  • racer54
  • racer54's Avatar
15 Nov 2006 16:42
#92412
I might be way off base here, but I think motorcross bikes use removable risers in their top tree clamps(or so I've been told), so you can just bore holes in the right place and mount the risers to the ZX7 top trees. I'm hoping there's some truth to it. Has to be someone who makes risers so it would just be a matter of finding some and making the necessary mod.s to make it work.
  • caffcruiser
  • caffcruiser's Avatar
15 Nov 2006 17:11
#92425
Wait till tomorrow night. I can check the fiche at work and see what interchanges with the upper clamp for your bike. That way you'll have a list of what clamps you can use.
Also, for the clamps, the best bet is to get on Ebay and look for SV650 bar clamps. A lot of the SV guys swap to clip ons, and when they do so, they get rid of their bar clamps.
I've bought them for like $15.00 before.
Hell, we might even have a pair sitting on the shelf at work. I'll look around for ya.
As for the mounting, what you'll need to do is drill two holes for the clamps to mount.
Gimme a day or two to check into things and maybe sort you out with something.
Post edited by: caffcruiser, at: 2006/11/15 20:11
  • 77KZ650
15 Nov 2006 18:41
#92445
thx a lot guys
  • steell
  • steell's Avatar
15 Nov 2006 18:45
#92447
The KZ750 twin uses bolt on risers as well, just need to drill one hole on each side then bolt them in.
  • 77KZ650
15 Nov 2006 18:49
#92450
cool, and if all else fails, I can get some nice shiny billet ones here
