'81 550 GPz wheels
- cpgpz
'81 550 GPz wheels
14 Nov 2006 17:18
I have been told that it would be a good idea to replace my '81 seven spoke wheels with lighter '82 five spoke wheels. Has anybody done this? Any ideas or advice?
I decided to go ahead and do this.
I found some '82 five spoke wheels, sans roters. Front was 12 lbs. rear 14 lbs. My '81 wheels weighed front 14 lbs. rear 17 lbs. This is a significant reduction in unsprung weight! :laugh: Only problem is that my seven spoke roters have a different bolt pattern. :ohmy: But, I found a set of "82 roters and they are on the way. :whistle: I will report back when everything is bolted back together.
Post edited by: cpgpz, at: 2006/12/09 12:24
- cpgpz
Re: '81 550 GPz wheels
09 Dec 2006 10:16
I am replying to my own post to get it re-posted. Obviously I need to learn how to navigate this forum.
- wireman
09 Dec 2006 10:23
will your calipers and mounting brackets work with the differant rotors?
- neilage66
09 Dec 2006 13:01
cpgpz...why are you so interested in the 5 pound weight savings? Are you into vintage racing or something?
www.gpz550.com/gpz550/
There are some racers on the GPz forum if you are interested. Click on the "messages" tab and you'll see a link to the "discussion forum" which is searchable...enjoy!
Post edited by: neilage66, at: 2006/12/09 16:04
- cpgpz
02 Jan 2007 16:04
OK,I'm finished with this project. It turns out that the '82 wheel assemblies are 2 lbs. lighter in front and 4lbs. lighter at the rear. This is unsprung weight, so I believe that it is wourth it.
I have about 300 miles on this bike since the change and everything works. I had to use the '82 brake disks; the '82 axel spacers; the '82 sproket hub and the '82 speedo drive. My thanks to the guys at Rice Paddy for finding all this for me.
The '82 disks are the same size as the '81's but have a different bolt pattern because of five spoke wheels instead of seven. The '82 spoke hub is also down sized from the '81 but uses the same sproket.:whistle:
I am a racer, but I race vintage sports cars. I have never raced a bike at a race track.
- neilage66
02 Jan 2007 17:18
Glad things turned out well with the conversion.
What kind of "vintage sports cars" do you race?
Just curious, and we like pictures too!
- rstnick
02 Jan 2007 19:06
Vintage car pics would be great.
I'd be interested in knowing if this swap could work on 77-80 KZ650s.
Got pics of the bike too?
Before and after.
Could you measure:
1.The dia. of the discs, front and back? Is it dual disc up front?
2. The distance between the front discs, centre to centre.
3. The thickness of the discs, front and back.
4. What size rims, front and back?
5. What size axles do the GPz's use?
Post edited by: rstnick, at: 2007/01/02 22:14
Before and after.
Could you measure:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
