wide -tire appl.
- enfuego83
wide -tire appl.
13 Nov 2006 17:50
Im looking into a wide tire(250mm)application for a kz1000. Any advise??
- wireman
Re: wide -tire appl.
13 Nov 2006 17:56
a 1428 and nitrous to turn it!:S
just kidding you are in for a major boatload of work and lots of money to make it work though up to a 180 can be done with a little work once you pass that point you are into serious fabrication;)
- enfuego83
13 Nov 2006 18:10
Well Im Looking into a rigid frame from cycleone and I understand pmfronline makes offset sprockets for kz's but I dont know anyone that has used them. I'd like to do this w/o a jackshaft if possible but all the metric chops ive seen that wide have had jackshafts.
- wireman
13 Nov 2006 18:14
if you are using a frame thats already set up for it thats half the battle then put your back wheel in and figure out what it takes to connect it to your driveline;)
- enfuego83
13 Nov 2006 18:20
Yeah, Im just trying to get an idea how doable this project will be before I start throwing my money at it.
- enfuego83
- 77KZ650
13 Nov 2006 21:38
trac dynamics $ells 240 kit$ with no jack shaft and 300 kits with for the new sport bikes. if a stock sport bike swingarm and wheel can be made to fit a kz, i dont see why their kits wouldnt be able to as well. you could buy one from them, or just copy their design:evil:
or: copy the drag bikes that run the wide slicks and just put a street tire on the wider rim
Scott
Scott
07 MDP Rookie of the Year
- enfuego83
14 Nov 2006 20:45
OK, do they sell offset sprockets alone? this is for a hardtail frame so I don't need the swingarm. I cant seem to open the page, do you have a link?
- 77KZ650
15 Nov 2006 07:14
there are lots of places to buy offset sprockets(or make one of your own if you have the right stuff)
tracdynamics.com <--click
their page is messing up again....it only opens part way...you can open up the catalog though...
Post edited by: 77KZ650, at: 2006/11/15 10:20
