79 KZ1000ST front caliper bolt lube
- steveskz
05 Nov 2006 14:16
Hi, have a 79 kz1000st that I removed the right side caliper,pisto ring looks OK but the 4 ea bolt seals that the 2 bolts go through were torn up and it looks like that was the cause for the black streaks. Would like to know what type of lube is used on these bolts? thnks
- wireman
Re: 79 KZ1000ST front caliper bolt lube
05 Nov 2006 14:32
well since it shows my name as posting something i guess i might as well say something!
those black boots are meant to keep the gunk off of the slider bolts and can be a major pain in my experiance.i always plate mine so they slide pretty easy with nothing on them but you might try a little hi-temp grease on them,not too much though so it doesnt get hot and drip on pads or rotors;) goodluck,happy wrenching!
- hwms
05 Nov 2006 16:28
A little dab of high temp wheel bearing grease
- fixer5000
06 Nov 2006 13:13
i used some mobil synthetic grease on both of mine. so far so good. they slide nice now...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
