Brake braket question
- Snakebyte
02 Nov 2006 08:44
Here is a pic of the brake brakets that I have and they are not what I need. The location of the caliper on the rotor is were it should be located. So I'm still searching for the corect braket. Does anyone have one? The swingarm is off a zx 1995-I believe. I do have two brake brakets up for sale or trade:lol: Also a essentric for the shock and two dog bones. The dog bones are too long I'm going to need shorter ones.
- Snakebyte
- 77KZ650
Re: Brake braket question
02 Nov 2006 19:21
why cant the caliper go under the swingarm with the lower mount? its from a zx7?
Scott
Scott
07 MDP Rookie of the Year
- Snakebyte
03 Nov 2006 09:48
Tryed that and it does not work due to the caliper braket. With the caliper under the swingarm, the caliper does not wrap around the rotor properly. I'll take another pics to let you guys see what I'm talking about.
- Snakebyte
03 Nov 2006 09:55
On second thought about the dog bones I'll just do what Lorcan did to his dog bones. He has adjustable ones on.
- Snakebyte
03 Nov 2006 15:32Attachments:
- Snakebyte
03 Nov 2006 15:34
Another position. I was trying to mount it to the bottom of the arm but found out that it would not work due to the angle of piston and braket assembly.
- Snakebyte
03 Nov 2006 15:36
The only way for it the fit with the braket to mount it under the swingarm would be to mount the piston side of the caliper on the inside instead of the "normal" outside.
- Snakebyte
03 Nov 2006 15:39Attachments:
- Snakebyte
03 Nov 2006 15:45Attachments:
- 77KZ650
20 Nov 2006 09:31
I think you need the type of bracket pictured in
this ebay auction
- MDawnz1
21 Nov 2006 23:09
From looking at your photos.
It HAS to go on the top of the swingarm or you CAN'T bleed the brake.
1974 Z1a, still 903
