Where can I find a 30x47x15 tapered...
- Fossil
01 Nov 2006 16:08
...roller bearing? (upper steering head bearing for fork swap).
- wireman
Re: Where can I find a 30x47x15 tapered...
01 Nov 2006 16:45
got a precision bearing up around those parts?
- steell
01 Nov 2006 16:48
How about a 30x48x15 and enlarging the hole by .040" (removing .020" from the wall)?
If that would make the wall to thin, you could weld a ring around the outside to strengthen it.
The simple answer is to have a machine shop make a new stem and press it in. I know you said you don't want to do that, but it shouldn't cost much and then it would bolt right in to the standard bearings.
- RomSpaceKnight
01 Nov 2006 20:09
An industrial bearing supplier such a CBS (Canadian Bearing Supplies) should carry one. We also have a Lou's Bearing in London. I've always purchased my bearings from CBS. Tapered roller for steering heads are an arm and a leg from Kawi. Pennies from CBS (not literally but relatively so).
