kz1000 chain questions
- riverroad
- 1980 1000LTD B4
30 Oct 2006 09:14
Did the 1980 KZ1000 come from the factory with an o-ring chain? Mine has one, but it's about stretched to the max. It looks to be a 630 chain.
I'm thinking about putting on a 530 chain and sprockets.
Anybody know how many links I'm going to need for this stock swingarm bike? And what size sprockets I need to keep it at or about the same drive ratio?
Re: kz1000 chain questions
30 Oct 2006 09:23
Recommend Z1Enterprises.com
Post edited by: Patton, at: 2006/10/30 12:24
- hydrolazer
30 Oct 2006 16:50
ditto pattons statement,,,jeff at z-1 can fix you up
\'79 kaw 1000 ltd
- arai59
30 Oct 2006 17:52
I believe the bikes used standard chains. And it would have been a 630. Depending on how often you ride and environment a standard chain will suffice. Also regular cleaning and lubing will extend the life. Switching to the 530 is optional. As mentioned Jeff can probably help you in the conversion. They are stronger chains though being smaller. Not to mention the weight difference.
- RonKZ650
30 Oct 2006 18:51
They did use a 630 oring chain from the factory. Personally I would rather keep the stock 630 size chain on a KZ1000.
- riverroad
- 1980 1000LTD B4
01 Nov 2006 04:32
Thanks for the Z1 enterprises info guys.
I have heard that switching to 530 chain is a good idea. Just as strong and saves a couple ponies.
I'll probably go with a standard chain. I don't mind taking a chain off and soaking it in kerosene, drying it out, then soaking it in ninety weight. That's the way I used to do it back in the seventies anyway.
Anybody else have a special chain ritual or a more modern method they'd like to share?
