frame differnece between kz650 and kz650sr
  • fuzzwardo
  • fuzzwardo's Avatar Topic Author
28 Oct 2006 09:21
#88000
Is there any frame differences between these two for the years 1978 and 1979?
1978 Kz650B
2001 ZX9R
1996 zx9r project
1985 Suzuki SP250
1991 Harley Electra-glide classic
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: frame differnece between kz650 and kz650sr
28 Oct 2006 09:30
#88005
The rear loop of the frame is different. I believe the D's (SR's) is shorter as the two grab rails are shorter as well. The mounting tabs from the B & C rear tailpiece are not present on the D (SR) either.
Also the SR's will be diffrenrt than the B models, as in the SR uses a disc brake in back and has the mount for the rear master cylinder (as does a C model) but the B having a drum back brake doesn't need the mount.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
