No Speedo drive...options?
  • Fossil
  • Fossil's Avatar Topic Author
25 Oct 2006 15:19
#87284
Picked up a GSXR750 front end, and a ZX9 wheel, with no speedo drive. Any suggestions how to run a speedo...is there a version of the electronic bicycle speedos available?
  • 77KZ650
  • 77KZ650's Avatar
Re: No Speedo drive...options?
25 Oct 2006 15:41
#87289
was the zx9 the wheel came on old enough to use the mechanical speedo drive? if so, just get it and the zx9 speedo and you will be all set
07 MDP Rookie of the Year
  • Fossil
25 Oct 2006 15:53
#87292
I remember you saying before that you had a problem fitting a ZX wheel with speedo drive into a GSXR fork, well, I got all this and late 6 piston calipers with a remote reservoir master cylinder in a trade. Figured I couldn't lose, and did check if the wheel fit. I don't know what year the wheel is but it doesn't look like a speedo drive can be fitted.
  • StreetfighterKz
  • StreetfighterKz's Avatar
25 Oct 2006 16:13
#87293
The Zx9 will fit the GSXR axle but you're going to have to trim 1/4" or more off the Zx speedo drive to squeeze everything in the Gixxer forks. Like I said I ran into the same problem and ditched the Zx rim. I could have went with an electronic speedo (like I did on the bike in my avatar) but I wanted to keep the original gauges on my 'Stripfighter. I did find a cool solution that I may upgrade my 1000 to in the future. Take a look.. www.electrosport.com/electrosport_speedo_3900.html It has everything you would want for a decent price. There's always my next streetfighter project...:whistle:
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • geerbangr
  • geerbangr's Avatar
25 Oct 2006 16:36
#87303
Speedo ??? WTH you need one of those for ????
:woohoo: :silly: :woohoo: :silly: :woohoo: :silly:
1978 KZ 1000
I go by Jason
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
25 Oct 2006 17:07
#87308
Hey Fossil,
I recently put a Sigma brand BC1106 on my bicycle and was told by the bike mechanic that he sells a bunch of them to motorcyclists. The installation was easy and it's really programmable for any size wheel.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • pyxen
  • pyxen's Avatar
27 Oct 2006 04:56
#87741
Bicycle speedos would work fine for you folks in the states who are used to mph - it'd be tougher for us Canucks who are regularly in the triple digits when highway cruising. I guess it means that we'd have to learn the 'old' mph way. ;)
84 KZ550-F2 LTD
93 ZR550-B4
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
27 Oct 2006 06:20
#87756
I read somewhere that a guy took the speedo drives out of the new and old rim and was able to switch them by removing the pin that holds them in place.this alowed him to use stock speedo .try the arcives here and at "cyclemadness".It may have been a diff rim but it has been done. if you look through the guys bike pics,you may see one with your rim and stock guages,then you could pm them and ask how.good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Fossil
27 Oct 2006 21:13
#87912
Later, Doug
That's exactly what I hoping to find. Thanks. Sure will clean up the Buck Rogers style dash boards.
