wide tire for a 78 KZ1000?
- Bicycle Lee
24 Oct 2006 19:47
So...I'm a newbie...
What would it take to get a wider tire on the rear of my 78 KZ1000 police bike?
1978 KZ1000 police
- 77KZ650
Re: wide tire for a 78 KZ1000?
24 Oct 2006 20:10
how wide? I think a 140 fits the stock stuff, more work is needed to go really wide, read sig
07 MDP Rookie of the Year
- StreetfighterKz
24 Oct 2006 21:37
77KZ650 wrote:
I agree. If you do a search on here there are quite a few threads that cover this. If I can give one piece of advice its "Research, research, research."
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Bicycle Lee
25 Oct 2006 09:53
yeah, I was thinking more along the lines of a 200 or up...
1978 KZ1000 police
- StreetfighterKz
25 Oct 2006 16:19
A 200 is doable but its going to require quite a bit of work since a 5/8" offset chain/ sprocket combo sometimes barely clears a 190. You're most likely going to have a chain that wants to take up the same space as the frame rail at the swingarm pivot. Unless you run some sorta jack shaft setup like on the big tire 'Busa, Zx's and such. Then you could run the stock front sprocket and clear the frame just like with the stock rim. You would just have to come up with a good design to tension the chain between the engine and the jack shaft. Hope this helps.
Later Doug
Later Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 77KZ650
25 Oct 2006 16:24
- 77KZ650
25 Oct 2006 16:26
- wireman
25 Oct 2006 16:27Please Log in or Create an account to join the conversation.
- Bicycle Lee
26 Oct 2006 08:17
eh....I'm over it. I'll keep my standard wheeland tire. I just figured that it might be a softer, smoother ride with the wider tire now that it's a hard tail...
1978 KZ1000 police
- kzwolfsr
27 Oct 2006 11:42
Why dont you post some pics of hte bike you got there? It looks pretty interesting. Is that the police bike uin that picture?
Original man of the Caribbean
- Bicycle Lee
27 Oct 2006 21:11
It sure is. I'll post some pics when I get some.
1978 KZ1000 police
