2 pair
- leitrum
2 pair
09 Oct 2005 17:46
:blink: 81' kz 440b are there 2 sets of brake shoes on front drum......and does anyone know where to find at a reasonable cost. thx to isben22000 i found at denniskirk, but were pricey. if there are 2 sets it would be down right expensive from denniskirk.....
- AbyssDncr
Re: 2 pair
09 Oct 2005 18:18
Kawi shows it as the same as the '78 KZ400C as well as others. However, I also see that 41048-019 has been superseded with 41048-1090. Perhaps, Biquetoast can to a p/n where used query for that p/n so that you could search CK to see if something else shows up under other listings.
Good luck,
EDIT: Ron Ayers shows $38 for the front shoes and $24 for the rear shoes for Kawi parts. I know DK has rear shoes for $21 as well.
Post edited by: abyssdncr, at: 2005/10/09 21:21
Good luck,
- leitrum
Re: 2 pair
09 Oct 2005 19:19
thx for the info. but still need to know are there 2 pair of shoes on front drum or 1. and denniskirk have the fronts for 33.00. found them for 21.00 from bikebarn but are back ordered.
- AbyssDncr
Re: 2 pair
09 Oct 2005 19:46
There is only (1) pair of shoes...check out your bike on
www.buykawasaki.com
. Choose "owner info" and "parts diagrams" the rest is self explanatory. Check out the diagrams there for all your parts needs! ;)
- leitrum
Re: 2 pair
09 Oct 2005 20:00
thx for the info, something i read about reinstalling had me thinking there could be to sets....
- ibsen22000
- Visitor
Guest
Re: 2 pair
10 Oct 2005 05:06
There is only one pair (two shoes). And as I wrote in the post on the old site, all the front drum brake 400 and 440 models are using the same shoes.
And BikeBandit do have them: Parts # 587828-001 SHOE-BRAKE (KZ400S)US FRONT HUB/BRAKE, but the price is $24,64 for one shoe, $49.28 in total
- leitrum
Re: 2 pair
10 Oct 2005 17:14
i'm up to speed thx, you guys are great. originally ordered from bikebarn. are backordered so i took your advise i ordered from dennis kirk will be here on friday...are u kidden bikebarn sells as one piece, have to be installed as pairs. very misleading
