78 Z1R Handling
- arcaneman
78 Z1R Handling
24 Oct 2006 06:01
I have a 78 Z1R I would like to improve the handling on. Does anyone have some suggestion in regard to fork braces, steering dampers, different forks etc. Would also like to know brand name, model for any of the above if someone could recommed. Any other suggestions would be appreciated.
Thanks
Mike
Thanks
Mike
- wiredgeorge
Re: 78 Z1R Handling
24 Oct 2006 06:12
I would start with the basics before adding other stuff... install new wheel bearings, tapered steering stem bearings and tapered swingarm bearings. I would put some Progressive fork springs in as well as some Progressive 12 shocks (or other good quality shocks) and use some good tires. If you own a Z1, you probably know that your frame has some places where there are extra welds (compared to the Z1) and you could add a couple more to stiffen the frame which is essentially the problem with any 70s vintage Z/KZ and last, to get rid of any head shake, a steering damper is in order. If you have a steel front fender, be sure to keep it as it adds rigidity and acts as a "fender brace"... I don't think anyone is making braces anymore so one would have to be fabricated I guess or you might find one on eBay. I am not sure of the dimensions but there are probably braces made for other bikes that would work. Last, you mentioned new front ends... lots of folks have switched the entire front end with a more modern bike. Just make sure you get the full brake system, axle and wheel, etc to make the swap less of a chore. I don't care for this alternative as it doesn't much preserve the original bike but if you are looking for better handling, this is an option but I wouldn't forego the new bearings and better tires...
- arcaneman
Re: 78 Z1R Handling
24 Oct 2006 06:37
Thanks
That seems like a logical point to begin. I will start there as I would perfer to retain the orginal look of the bike. - Mike
- rstnick
Re: 78 Z1R Handling
24 Oct 2006 06:52
Welcome Mike.
Give of some pics of your collection.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
