<<<>>>Catch-22 Clymer manual Catch 22
  • JMKZHI
  • JMKZHI's Avatar Topic Author
23 Oct 2006 17:42 - 22 Feb 2013 11:33
#86649
Catch-22 Catch22 Catch 22
I found this info in the Clymer manual rather amusing: chapter 3 says to see chapter 8 for free play adjustment; chapter 8 says to see chapter 3 for free play adjustment.
Last edit: 22 Feb 2013 11:33 by JMKZHI.
  • flht1997
  • flht1997's Avatar
Re: Steering Stem Installation
23 Oct 2006 18:00
#86650
22ft pounds really will not feel like much. and if it feels a bit tight now it should feel ok when you get the forks and wheel back on.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • JMKZHI
Re: .
25 Oct 2006 05:46 - 22 Feb 2013 11:30
#87132
Last edit: 22 Feb 2013 11:30 by JMKZHI.
  • OKC_Kent
  • OKC_Kent's Avatar
25 Oct 2006 05:52
#87134
When I tightened my notched locknut, it was tight enough to let the complete front fork assembly gently flop from center to side under it's own weight, with just a light tap on the bar end to get it moving. I read that somewhere, maybe the Clymers manual.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • JMKZHI
Re: .
25 Oct 2006 08:56 - 22 Feb 2013 11:31
#87184
Last edit: 22 Feb 2013 11:31 by JMKZHI.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
25 Oct 2006 19:43
#87375
I'm having the same issue right now. I'm not sure how tight to go and haven't been able to get a good answer in any other posts. I've never seen an adapter for the spanner nut and was hoping for some solid advice. I'll keep watching and hope that someone else chimes in.
The Kaw List:
  • racer54
  • racer54's Avatar
26 Oct 2006 01:45
#87416
I tighten by hand then keep tightening the stem nut till all slop is taken out. I rock the trees side to side and front to back to be sure there isn't any play. I try to get it tight enough for no play but it will fall to either side under it's own weight. If you can feel any tension in moving it side to side...you are too tight. Once "slop" is gone, tighten just a bit more.
  • JMKZHI
Re: .
26 Oct 2006 05:25 - 22 Feb 2013 11:31
#87433
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
26 Oct 2006 09:07
#87502
JMKZHI wrote:
I found this info in the Clymer manual rather amusing: chapter 3 says to see chapter 8 for free play adjustment; chapter 8 says to see chapter 3 for free play adjustment. :blink: JMK.
That sounds about right!! :blink:
I have read about the other guys tightening the stem until there is just a little bit of resistance, but I could never find out if that was just the triple tree or with the whole front end together. Than makes a very big difference. If the fork assembly (with fender, wheel, etc...) should swing side to side on it's own, the torque on the nut would make just the triple trees seem tight (with no other parts installed). Make sense?? I guess that's where I really need the clarification. I was also hoping someone might have a way of torquing it accurately, but I have never seen an adapter for that.
The Kaw List:
  • racer54
  • racer54's Avatar
26 Oct 2006 16:15
#87608
I do it with the front end on it. I grab the end of the fork legs and use them for leverage. You figure you will be riding it with the forks on it and with the added weight, they will put more stress on it also. You want to duplicate actual riding conditions the best you can. It doesn't take much leverage though. Just move it back and forth in different directions and feel for any looseness. If it's too loose, you will feel it. Once I have it where all the "slop" is taken out, I usually tighten it just a wee bit more.
  • JMKZHI
Re: .
27 Oct 2006 08:29 - 22 Feb 2013 11:31
#87788
