speedometer drive unit
- riverroad
- 1980 1000LTD B4
23 Oct 2006 11:42
Hi, Newbie here.
I just bought a 1980 KZ1000 LTD. Mechanically sound, but ugly as sin (rattle can paint job).
First thing I need to fix is the speedometer drive unit.
Anybody know where I can get a new one? Are other model Kawasakis the same (interchangeable)?
And I think I'd also like to replace the speedometer anyway, because the 80mph speedometer just looks plain ridiculous on a KZ1000. After getting to know this beast all weekend, I'm pretty sure she'll do at least a little bit over eighty.
- btchalice
Re: speedometer drive unit
23 Oct 2006 14:41
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- riverroad
- 1980 1000LTD B4
25 Oct 2006 06:36
Thanks Btchalice, I'll keep that in mind, but first I gotta get the speedo cable turning before I concentrate on the gauges. That does look a lot like my setup though.
- JMKZHI
Last edit: 03 Dec 2008 16:50 by JMKZHI.
- OKC_Kent
25 Oct 2006 08:37
You should be able to adapt a higher reading speedo pretty easily, I think.
I have a drive unit, part number 41078-008. It is for my 650 speedo. My cross reference software says it will swap only up to KZ1000 1979. But whether that is due to the switch to 80 mph speedos I don't know, or axle size..?
If you can't find one or adapt something to a newer or higher speedo let me know, I'll send it to you for postage. I don't know the axle hole size in it, it's for a 78 650 B2.
update
Hey now that I look at the part numbers used on my front hub and your front hub, this drive assy should fit just fine. Let me know if you want it.
Post edited by: OKC_Kent, at: 2006/10/25 11:43
update
Cashion, OK
78 KZ650 B2 85,000+ miles
- riverroad
- 1980 1000LTD B4
25 Oct 2006 09:18
Thanks for the link JMKZH1. I've book marked it. I have a feeling I'll be using it quite a bit.
OKC_Kent, I pm'd you on that speedo drive unit
