'77 KZ 1000 front end
  • RonnyP
  • RonnyP's Avatar Topic Author
18 Oct 2006 15:51
#85286
I am looking for imformation on what of the early KZ's front ends, (triple tree, tubes, lower legs), are compatible with the KZ 1000. I crashed my ride almost 3 weeks ago, and have been looking on ebay for replacement parts. I see a few KZ 750 units out there, are they adaptable to my bike? If not, what may be?
About the only thing on the front end not damaged were the wheel, tire, handlebars, and mirrors. Headlight, guages, triple tree, forks and fender are trash!
Thanks in advance,
Ron
  • steell
  • steell's Avatar
Re: '77 KZ 1000 front end
18 Oct 2006 16:29
#85294
78-79 KZ750 twin front end should bolt on, although you may want to use the original 1000 fork springs.
  • wireman
  • wireman's Avatar
18 Oct 2006 19:36
#85329
id say 77-80 kz1000 and ltd,kz650 uses same front end but tubes are a little shorter if you want to lower bike a little;) im not sure about the 750s,steell is the in house 750 king!:P
  • RonnyP
18 Oct 2006 20:28
#85343
Thanks for the input! I am getting pieces off of eBay to get back together. Made out good on a lot of the parts. Hopefully, I'll be able to ride within a month.
Damn, I used to bounce, now I just splatter! 56 and finally feeling it!
  • wireman
  • wireman's Avatar
18 Oct 2006 20:38
#85351
yeah i dont bounce anymore either!i just kind of lay there and try and remember the good ol days when i could still bounce!:blink: :S :whistle: :P
  • btchalice
  • btchalice's Avatar
19 Oct 2006 05:05
#85391
what part of the country are you in? i have a set of 750 forks collecting dust in the garage
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • steell
  • steell's Avatar
19 Oct 2006 05:35
#85403
Here is a site that used to sell fork tubes but they left the list up for reference.
It shows 77-80 KZ1000 fork tubes as being identical to 78-79 KZ1000 fork tubes. I know they are because I used 78 KZ1000 fork tubes when I replaced the extended tubes on a 79 KZ750 twin :)
www.rev-um-up.com/fork-tubes-honda-kawaski.htm
KZ650 and 76-77 KZ750 tubes will fit, they are an inch shorter though.
Post edited by: steell, at: 2006/10/19 08:37
  • wiredgeorge
  • wiredgeorge's Avatar
19 Oct 2006 06:15
#85425
I have an early Z1 front end on one of my KZ900s and a 79 KZ1000 LTD front end on the other. Just get the whole mess including brakes to make the swap easier...
  • RonnyP
19 Oct 2006 12:05
#85466
I'm on Cape Cod, MA. I located a 36mm front end on eBay with lower legs in decent shape from a KZ750B.
Thanks for the "tube site!" The tubes are an inch shorter than the KZ1000 tubes, I was looking for a lower ride as I only drive solo. No need having two poeple getting banged up! I need a lower leg which are included on the deal.
Thanks again for the assist. Now I only have to work the dents out of the gas tank!
