sprocket ??
- BSKZ650
sprocket ??
15 Oct 2006 05:48
after the nut came off the 1000 I noticed the splines on the back side , installed, had been taperd, I assume because of the nut coming off, the question is, is there a problem with flipping it around to make sure the spline contact is better?
77 ltd1000, current rider
76 kz900, just waiting
- Nevco48
- BSKZ650
Re: sprocket ??
15 Oct 2006 07:20
it looks flat without any shoulder on either side
- pstrbrc
- '81 GPz 1100 project
Re: sprocket ??
15 Oct 2006 07:28
As long as it's not worn very much. As a chain stretches it wears the sprocket, shanging the shape of the curve where the roller fits in. If you flip it over the wear will be in the opposite direction. I'm not sure what symptoms you will experience, but I can't help but think that this would not be a happy relationship. At the very least you would probably experience excellerated wear on both the chain and the sprocket. Since front sprockets aren't terribly expensive, and since You already have it apart, I'd advise springing for a new one.
"There are three possibilities when you pass the football, and two of them are bad."
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
