steering damper
  • jeffsargent
  • jeffsargent's Avatar Topic Author
steering damper
13 Oct 2006 06:01
#83882
I am restoring an '82 KZ1000J. Included in a crate of parts was this steering damper, which may be from an '81 KZ1100B, which the previous owner also had. Can anyone provide any advice on where and how this attaches? Thanks.[img =150]link to image [/img]
Post edited by: jeffsargent, at: 2006/10/13 09:25
Post edited by: jeffsargent, at: 2006/10/13 09:28
Post edited by: jeffsargent, at: 2006/10/13 09:52
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: steering damper
13 Oct 2006 06:40
#83895
Keep trying Jeff...I will add though, that steering dampers were not original Kawasaki equipment, so if you are restoring....leave it off. But if you want it to improve handling, then install it.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • barney
  • barney's Avatar
Re: steering damper
13 Oct 2006 08:24
#83931
Jeff . I've mounted my steering dampers body to the area where the side reflector was originally mounted (left side is preferable)there are two holes there (one threaded and on not) you may need to fabricate a bracket of some kind to attach to this area. The other end(rod end) will require fastening to a fork tube clamp(you can get one of these aftermarket at your local bike shop). McD is correct they were not originally installed. Eddie Lawsons S1 racebike had one though
  • jeffsargent
Re: steering damper
13 Oct 2006 12:17
#83980
Thanks; I think I'm with you. Any chance you could send a picture of how you did it? I know where the reflector holes are, but it seems like it would hit the tank in this location, no?
Jeff
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
  • barney
  • barney's Avatar
Re: steering damper
14 Oct 2006 07:14
#84206
Jeff. Sure no problem. Although the pic that Kano submitted pretty well explains what I've done.I mounted my damper higher up than his though(about an 1/4" below the lip of the tank), doesnt hit the tank at all.I mounted the fork tube clamp above the lower triple where as Kano appears to have mounted his below the lower triple. Either way will work I think, just depends on how close to the tank you want to mount the other end.
  • barney
  • barney's Avatar
Re: steering damper
14 Oct 2006 07:21
#84209
Does this help
  • barney
  • barney's Avatar
Re: steering damper
14 Oct 2006 07:33
#84212
Stupid camera
  • barney
  • barney's Avatar
Re: steering damper
14 Oct 2006 07:45
#84216
Check my picture in the gallery under KZ1000, titled Damper. Dont know why I cant download it to here. Go figure.
  • jeffsargent
Re: steering damper
20 Oct 2006 08:04
#85689
Thanks! Very helpful!
jeff
