Swing arm choices
- mark1122
- Keep twisting it
Swing arm choices
11 Oct 2006 10:05
What are the best options for swingies for a 180 to 200 tire on a KZ900? In order of eaz of fit?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Duck
- e vica na i sau na ga
Re: Swing arm choices
11 Oct 2006 12:01
Don't know about 'best' but I have the Aluminum swing arm, shock, and rear frame section from a bandit 1200 that I'm never going to get around to using. Can get you photos over the weekend. -Duck
kzr add here. It has link to photos with measuring stick
180 will fit. 200 will be really tight and may or may not fit depending on the tire.
Post edited by: Duck, at: 2006/10/11 15:05
Post edited by: Duck, at: 2006/10/11 15:09
- 77KZ650
11 Oct 2006 18:13
read sig;)
it would be easier to weld the brackets on the swingarm to keep dual shocks, but I wanted the upgrade. just had to narrow the swingarm a bit at the pivot point to fit it in the frame, i think it was around 1/4 inch, plus drill the frame to accept the larger diameter pivot bolt
07 MDP Rookie of the Year
- mark1122
- Keep twisting it
13 Oct 2006 14:07
I like the dual shock look too.I think I will get a zrx1200 arm.Thanks for the offer Duck.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
