Fuel tank cleaning products for varnish (not for rust)
  • ten6
  • ten6's Avatar Topic Author
07 Oct 2006 20:18
#82564
Hey guys, I am trying to locate a good slime remover for a fuel tank. I have one varnished up pretty good. No rust as i can see but nasty varnish. What's the best thing to use on it? I would prefer products available at the local hardware store...Thanks.;)
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
  • EsaPro
  • EsaPro's Avatar
Re: Fuel tank cleaning products for varnish (not for rust)
07 Oct 2006 20:22
#82565
If rust is not the issue, how about carb cleaner or seafoam? Maybe a bottle brush or something similar to agitate & scrub.
Jim
79 KZ750 Twin (Fun!)
07 Yamaha 1300 (Plush!)
  • OKC_Kent
  • OKC_Kent's Avatar
07 Oct 2006 20:42
#82569
Be careful if you use a carb dip like Berrymans, it WILL remove the paint. DAMHIKT
Cashion, OK
78 KZ650 B2 85,000+ miles
  • ten6
07 Oct 2006 20:51
#82570
well guys, paint removal isn't an issue either...it's bare metal already. I thought of Berryman's but nobody around here keeps it in stock it seems. It's special order. Any ideas about paint stippers or anything of the kind?
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
  • wireman
  • wireman's Avatar
08 Oct 2006 00:20
#82585
acetone?;)
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
08 Oct 2006 06:46
#82589
I'd try a tank of fuel and let it sit a few days to a week. Use for 2-stroke lawnmower when done. If the gasoline wont take it off, it's not gonna be a problem :-0
-Duck
  • wiredgeorge
  • wiredgeorge's Avatar
09 Oct 2006 06:10
#82792
If you have varnished fuel in the tank and don't have a problem with paint being messed up, go to ANY autoparts store and buy whatever brand of carb cleaner in a gallon bucket they sell. Put in a gallon of this stuff and top the tank off with gas and let it sit for 24 hours. The Berrymans stuff is the strongest but GUNK brand will also work fine as will the NAPA carb cleaner. The NAPA stuff is almost as strong as Berrymans but I don't use it for carb cleaning as it leaves an oily residue which wouldn't matter for the purpose of cleaning out the tank. I don't think gas by itself would have a lot of effect if the varnish is set up by age.
  • ten6
09 Oct 2006 22:21
#83070
Thanks for the relpies guys...I actually used a gel paint and varnish remover...followed by a rinse of laquer thinner...followed by a little rust remover (found some rust under the varnish) followed by some fresh gas...came out clean and ready to go. The sludge that came out was NASTY:dry:
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
  • Duck
  • Duck's Avatar
10 Oct 2006 05:59
#83118
Do not use carb dip for anything other than dipping. It's really NASTY health wise. That layer of oil in the can is there to protect the user!!!
  • wiredgeorge
10 Oct 2006 06:13
#83127
Duck, the carb dip is nasty but PLEASE read the label on some laquer thinner before deciding dip is the nastiest bully on the block. Laquer thinner is perhaps the nastiest chemical I own and I always use gloves and FULL respirator when using that stuff... It has all the bad stuff that carb dip has plus bonus killers hehe
  • ten6
10 Oct 2006 06:48
#83143
That's exactly why i used it (laquer thinner) It was used outdoors with good ventilation and all the proper precautions.
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
