Mastere Cylinder Honing
- bemoore
06 Oct 2006 05:23
I want to hone the bore on my front master cylinder. I did a Google search for hones and found 180 grit and 320 grit hones. Which one would be best? I'm leaning toward the 320 grit to get a smoother finish.
Thanks.
Thanks.
77 KZ650C1 w/Kerker 4-1
- ran429
- Master of FREE rides!
Re: Mastere Cylinder Honing
06 Oct 2006 09:53
I used WD40 and AAAA steel wool wrapped around a dowel placed in a drill. Worked like a charm every time i did it.
Make sure to clean out the master extrememly well with solvents & air before reassembling it. no need to buy expensive hones if you dont really need to.
- wireman
06 Oct 2006 10:44
ran429 wrote:
ditto,leave it to the low-buck plumbers!I used WD40 and AAAA steel wool wrapped around a dowel placed in a drill. Worked like a charm every time i did it.
- bemoore
06 Oct 2006 10:50
ran429 wrote:
Hmmmm. I like that idea. Thanks. BTW, is it critical to use WD40? I typically just use brake fluid. It seems to work pretty well as a lubricant.I used WD40 and AAAA steel wool wrapped around a dowel placed in a drill. Worked like a charm every time i did it.
- wireman
06 Oct 2006 11:06
thats fine,just make sure to scrub everything out really good with rubbing alcohal when you are done and dont get petroleum based cleaners on any rubber parts.
