Twin Question / also Forks
- Shoe48
- Live each day as it is your last
03 Oct 2006 16:15
I am looking to install double rotors for twin brakes on my 82 twin , I am wondering what rotors fits ? It uses the 4 bolt pattern .. are the 305 or 440 rotors the same ? also I bought a set of real nice Spectra forks ,, Has anyone ever had these apart ? I have never seen anything like this Top snap ring ? Looks like it needs pushed in to release the snap ring ,, Well anyway Thanks
- steell
Re: Twin Question / also Forks
03 Oct 2006 20:07
Does your ftont hub have provision for a second disk? I know the stock forks don't have a place to mount a second caliper.
Got to watch the diameter of the rotor as well as the mounting bolt pattern and spacing.
- Shoe48
04 Oct 2006 05:18
I am going to use the spectra forks as they have the extra caliper mount . I had hoped to remove the chrome cover on my stock front wheel to find the other rotor mount ,, Maybe I had better look first to see if it is the same as a kz650 wheel . ( Spokes )
- steell
04 Oct 2006 06:16
Spectre use the same size axle, and are the fork tubes the same length and diameter?
- Shoe48
04 Oct 2006 07:38
I bought a cheap set of Calipers from Harbor Frieght and the two fork sets are the same diameter and length .. axle size is yet to see ,, Spectra forks use a one side fill for the air so checking and filling could be a bit easier ,, I will know more when I get to doing it ,,
- steell
04 Oct 2006 19:32
Here is the Link to the "Rules" thread that has the picture posting info.
Rules Thread
Posted in response to a request via PM
Rules Thread
