Forward Controls
- Kellen79_650
Forward Controls
02 Oct 2006 08:40
So I have been looking for a set of forward controls for my bobber project and I cannot for the life of me understand why they run from $400 to $600 or more. Is there anywhere that sells a good looking set of no nonsense forward controls at a reasonable price?
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated and Scorned. When his cause succeeds however, the timid join him, for then it costs NOTHING to be a Patriot."
~Mark Twain
~Mark Twain
- Mikes82KZ1100
Re: Forward Controls
02 Oct 2006 08:51
I've seen a few for $250-300 on e-bay. I too would like forward controls but havent figured out how to make a shift linkage to work from sticking out so far from the shift shaft. I'm thinking of a "bellcrank" of some sorts but it looks to be a major pain to mount etc. You got any ideas?
- Draco
02 Oct 2006 09:33
Check this out guys. Looks pretty solid to me, I may be trying this during the winter.
Forward Controls
Forward Controls
- Mikes82KZ1100
02 Oct 2006 10:10
Great info! I didn't think about using the factory master cyl. I wish there were more pic.s of the shifter set up but there is enough to get the general idea and work with that.THANKS!
- Draco
02 Oct 2006 10:20
If you click the pics at the bottom, it opens a page that describes what all the parts are that you will need to do it right. If anyone tries this before I get a chance to, let me know how it works out!
- Mikes82KZ1100
02 Oct 2006 10:36
I just looked at the 1100 to see how it would fit and it looks VERY promising. I also looked at the Voyager parts bike and just about everything I will need for the shift linkage is there except a longer rod.(Heim joints, shaft connector, shift lever, pivot). Looks like the long Voyager brake pedal will work also with some bending. Since there is no chrome on the spectre, I can get by with some rattle can black
Thanks again Draco. You da man!!!!!
Post edited by: Mikes82KZ1100, at: 2006/10/02 13:39
- Mikes82KZ1100
- Draco
02 Oct 2006 11:24
Looks like a great start to me! be sure to take pics of your build up. take the pics that you wanted to see in the link I sent. Keep me posted!
