white-lettered tires
- mcat
01 Oct 2006 04:25
does anyone make raised white-lettered tires anymore?
i want to keep my 80 ltd 1000 close to stock in looks.
i ordered dunlap qualifiers last july and they're still on backorder from dunlap. what i've heard is that hd is putting them on the new sportsters and so we have to wait. argh!
i might have to go with plain dunlap 401s, which i've heard is a good cruising tire.
any thoughts?
thanks,
mcat:unsure:
any thoughts?
thanks,
mcat:unsure:
'80 LTD 1000
'70 BSA Lightning
'03 Triumph Speedmaster
'08 GL1800
'70 BSA Lightning
'08 GL1800
- ambergrismooon
Re: white-lettered tires
01 Oct 2006 05:05
I got new white raised letter Bridgestones last year for my 900ltd.
- mcat
01 Oct 2006 05:14
www.tiresunlimited.com/ALL%20TIRES/Bridg...one_spitfire_s11.htm
spitfires.
thanks
mcat
Post edited by: mcat, at: 2006/10/01 08:17
spitfires.
thanks
mcat
'80 LTD 1000
'70 BSA Lightning
'08 GL1800
'70 BSA Lightning
'08 GL1800
- ambergrismooon
01 Oct 2006 09:20
My bad....I should have said Spitfires! You filled in the blanks real good!
I like the tires.
- IowaKZ
- '80 G1 Classic
01 Oct 2006 17:54
I like them too. Next time I buy tires, I'm going to look at these.
1980 G1 Classic
Bettendorf, Iowa
Bettendorf, Iowa
- mcat
02 Oct 2006 08:17
1 last question.
i ordered 110/90/h19 for the front.
the stock is a 100/90/h19 but they are on bc.
will i be ok?
thanks,
mcat
will i be ok?
thanks,
mcat
'80 LTD 1000
'70 BSA Lightning
'08 GL1800
'70 BSA Lightning
'08 GL1800
- ambergrismooon
02 Oct 2006 08:33
I have 110 on my 900 which calls for a 100 but I have a different
fender and I have to deflate the tire to get it off between the fender
bolt heads.:blink:
Oh and before anyone asks I don't work or own stock in Bridgestone.......:ohmy:
Post edited by: ambergrismooon, at: 2006/10/02 11:34
bolt heads.:blink:
- neilage66
02 Oct 2006 17:52
So how are the dividends from Bridgestone btw?
:blink:
:silly:
:blink:
:silly:
- mcat
15 Oct 2006 06:40
i finally got my tires installed with the
110/90/h19 for the front instead of the 100. the tire rubs the fender-- sigh.
any suggestions on a replacement fender or mod to the old? i might try to drill another set of holes to raise the fender off the tire a bit...
mcat
mcat
'80 LTD 1000
'70 BSA Lightning
'08 GL1800
'70 BSA Lightning
'08 GL1800
- Prune1
15 Oct 2006 06:48
Is it just rubbing on the bolt heads? I had that issue and solved it by grinding down the bolt heads to half their orginal thickness. Havnt had the fender fly off....yet!
- mcat
15 Oct 2006 07:48
bolt head clearence is fine, it's the rolled fender edge I think.
mcat
mcat
'80 LTD 1000
'70 BSA Lightning
'08 GL1800
'70 BSA Lightning
'08 GL1800
