chassis reinforcement
- Exitpupil
30 Sep 2006 14:57
I posted in the engine forum about increasing the hp on my KZ1000 and several posters mentioned that the chassis needs help. Can anyone direct me to where I can learn where and how it needs to be upgraded? This is a street bike.
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- Vter Bob
Re: chassis reinforcement
30 Sep 2006 15:39
If your Japanese is good, give this site a try.
img.photobucket.com/albums/v12/wiredgeorge/frame_drawing.jpg
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- wireman
30 Sep 2006 16:37
swingarm pivot area and steering head and backbone area are biggest problem areas depending on what year of frame you are using.heavier solid motor mounts and oversize otor mount bolts can also help by using motor to tie tubes together.the swingarm is probably the biggest improvement you can make,pitch the stock arm and put a good aluminum swingarm on there.
- 77KZ650
30 Sep 2006 17:10
07 MDP Rookie of the Year
- Exitpupil
01 Oct 2006 06:26
Thanks for the advise and links. I can weld so it looks very doable for me. It's the swingarm that is giving me a headache on researching. So many to choose from, and none in front of me on a bench to look at. I want one not overly complicated to swap and about the factory arm length.
Post edited by: Exitpupil, at: 2006/10/01 09:27
- 77KZ650
01 Oct 2006 08:57
Exitpupil wrote:
get the GS1100 arm;)
heres a link for ya too
Post edited by: 77KZ650, at: 2006/10/01 12:26
- Fossil
01 Oct 2006 20:45
Check the links here on KZR. There's GPz modifications, and Tony Foale's chassis mods. Both for later bikes than yours, but some of the info is applicable.
- 77KZ650
01 Oct 2006 21:03
. a good read, and very useful pics
- wylderide
03 Oct 2006 16:05
is there anywhere to buy the kosman style kit for bracing or the heavy duty motor mount kits. needing one for my 76 900 drag bike
- wireman
- wylderide
04 Oct 2006 12:17
kosman is no longer available, and Jay from APE says he's never had them or has never seen them. It would just be quicker for me to get the kit. I'm busy as hell in the shop and for the $150 the kit was going for that's two hours of my shop time, and I"m sure it would take me longer than that to make all the peices. So last resort I could make the kit, but it would save me to buy one from somewhere. Thanks for all the help so far though.
- wireman
04 Oct 2006 18:00
kosman specialties $160.00 for frame kit,just looked it up.:whistle:
