37mm forks in 36mm tripples
  • jcleach
  • jcleach's Avatar Topic Author
22 Sep 2006 13:29
#78794
anyone know the chances of fitting 37s in a 36 tripple?
I was running old ex500 forks (1st gen) and bent one.
local yard only can get as close as 37s
  • Trav
  • Trav's Avatar
Re: 37mm forks in 36mm tripples
22 Sep 2006 23:00
#78885
Get your top and bottom triple trees machined. That's pretty much all you could do to fit oversized forks. Or swap the whole setup, triple trees and all.
I would think you could machine 1mm over.. maybe 2mm.
  • donthekawguy
  • donthekawguy's Avatar
23 Sep 2006 04:19
#78910
I would asy 0 to none without a bore job.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • jcleach
23 Sep 2006 11:16
#78957
answers my question. machining is not a prob. Iwas worried about the integrity of the clamps. Whats losing 1mm anyway,right?
  • Trav
  • Trav's Avatar
23 Sep 2006 13:03
#78978
I don't think it is much in this instance. Increasing the diameter 1mm only increases the radius by .5mm. The circumference increase should be very small.
If you had a 37mm clamp and you putting 36mm forks in it, and cranking down on the bolts, I would be much more concerned!
