rakeing a 76 900
  • wylderide
  • wylderide's Avatar Topic Author
rakeing a 76 900
20 Sep 2006 15:36
#78295
Just trying to find out what anyone else might have done. I've been thinking something like 5 degrees, but not sure yet. Doing my research. This is for my street/strip bike. I have a 8" over swingarm, wheelie bar, etc. Just doesn't feel real steady at 130. Also is there anyone on here that has done this before. With that neck configuration i'm still not sure on where to start the chop. Done lots of harleys but no kz'z yet. Thanks in advance.
  • wireman
  • wireman's Avatar
Re: rakeing a 76 900
20 Sep 2006 15:51
#78299
thats gonna be really steep for a street bike,im going about 2-3 degrees on my 1385 turbo project with about 3" over on swingarm its gonna be a streetbike though.;)
  • wylderide
20 Sep 2006 16:10
#78303
I will probably go 3-4 then. How about other bracing on the frame, to help reduce chassis flex. Any known good places for extra bracing. I have a pretty worked motor and will be adding a turbo to it after I have the chassis all worked out on the track. I've raced the bike lots before and it works ok. Kinda twisty and a little funny at real high speeds.
  • wireman
  • wireman's Avatar
20 Sep 2006 21:47
#78377
we are in the process of gusseting mine right now,ithink we are gonna work on it tomorrow night ,ill post more progress picks if we do.;)
  • KZ
  • KZ's Avatar
23 Sep 2006 16:23
#79016
I raked my '78 1K and it came out to about 31 degrees. Handles surprisingly well in the corners, goes straight down the road and looks a hundred times better (to me). I cut through the frame tubing such that I left about ½ inch "stubs" still connected to the steering head. I then inserted short lengths of tube inside the frame tubing and welded it up where they joined. I had to bend the smaller diameter tubes a bit to line back up with the stubs still on the steering head. I then welded side plates on for a bit more strength. I also extended my stock swingarm 3".
Here is an older pic
Post edited by: KZ, at: 2006/09/23 19:24
  • KZbilly
  • KZbilly's Avatar
27 Oct 2006 14:50
#87845
do you have any close up pics of your rake. I have been doing some work on my kz and was thinking about raking the front but wasn't sure. thanks. billy
  • customkzft
  • customkzft's Avatar
27 Oct 2006 18:08
#87870
Ok I'm still learning things but one question, what is involved in raking a bike? the neck has to be cut from the frame and rewelded right?
