EX500 front end measurements...
- Fossil
16 Sep 2006 17:26
I headed to my local bike wreckers today to take some measurements and spend some money, only to find them closed, and yes I did ask this here before, but here goes again....
Anyone have, or have access to an EX500? I need the centre to centre measurement of the stanchions and the offset measurement for those with 37mm stanchions. Thanks.
- NickD
Re: EX500 front end measurements...
22 Sep 2006 06:30
I thought I could help until you got to the 37mm part. Just for reference, '94 and newer EX500s use the 37mm forks; '93 and older bikes have the 36mm tubes.
I can ask on the EX forums next time it's up and running (server problems lately). I suppose by center to center you mean of the fork tubes/triple tree tube mounts? I'm lost on the offset part. Does that have something to do with the placement of the steering stem in relation to the fork tubes?
- Fossil
22 Sep 2006 08:47
Thanks, just knowing what years have the 37mm fork tubes helps a lot. You're right, the offset is the distance between the the stem and the tubes measured on the center. The center to center I was referring to for the fork tubes is the width of the forks. If this actually works, it will both shed some weight and I will be able to mount this Storz handlebar conversion, or use the higher EX500 clipons for comfort.
- NickD
10 Oct 2006 09:45
Did you ever find the info you need? I can try and reach a few EX500 riders I know to get some measurements if you still need them.
I didn't have notify turned on for this thread (and didn't know I had to manually turn it on), so I never knew you'd replied. The EX forums have been and are still down for the count, I don't know if they're coming back or not. I hope so.
- Fossil
10 Oct 2006 13:47
Thanks for following up on this. It started to look like it was going to be a lot of trouble, so I put it aside for a while. Then a friend offered a GSXR fork in trade so I was looking into/considering that for a while. As it stands now, I am keeping the clipons on it. I actually have the bike up for trade for a Brit bike (Commando, 650 Triumph, A10) but if that doesn't work out, I will just keep it and install the braided brake lines and progressive springs, and get around to painting the front wheel too. I will be selling the Storz handlebar conversion, eventually.
- NickD
10 Oct 2006 18:15
I think I've gathered what the Storz conversion is, but I figured I'd just ask. Does it convert the EX riser setup to a 7/8" handlebar mount? If so, let me know if you're looking to sell and how much, I may be interested.
On a side note, just for reference, you can get mid to late '80s ZX6 (not R) risers that will bolt directly to an EX triple but drop the controls about 2" or so lower. If that's something you're looking to do I can find out the specifics, but that seems to be the opposite way you were heading with your project. If so, I don't blame you
- Fossil
10 Oct 2006 18:30
The Storz bar conversion bolts into the clipon mounting holes and does convert to standard type 7/8" bars. I can get a pic tomorrow. I paid $50 CDN for it, so that's all I'm looking for, plus postage. I had hoped to use it to mount narrowed MX type bars ala Streetfighters.
edit: a quick Google around came up with this pic. It's virtually identical, but for the EX500
storz_performance
Post edited by: Fossil, at: 2006/10/10 21:35
Post edited by: steell, at: 2006/10/22 21:28
storz_performance
- NickD
22 Oct 2006 15:33
Fossil wrote:
Let me know if you decide you want to get rid of the Storz converter. The more I think about it the more I'm leaning toward converting mine to drag bars and sticking with the nekkid look.
Post edited by: steell, at: 2006/10/22 21:29
storz_performance edited by: Fossil, at: 2006/10/10 21:35
- Fossil
