Tires for a KZ400 D3?
  • KitNYC
  • KitNYC's Avatar Topic Author
10 Nov 2005 20:23
#7648
Hey folks:
Hypothetically speaking, if there was a '76 KZ400 D3 that needed a decent set of inexpensive tires, what might those tires be?
I'm not seeing anything out there in the specified 3.25" x 18" front, the smallest I've seen is 3.5" x 18". Rear tires don't seem to be available in anything less than a 4" width. Will these fit?
Any input on low priced tires that will work well for low speed, around town use?
Cheers,
-Kit
  • georgeha
  • georgeha's Avatar
Re: Tires for a KZ400 D3?
11 Nov 2005 06:02
#7685
I'm using Chen Shin's on my 75 400. I've heard they're not very grippy, but I have no basis for comparison, and the bike feels wobbly enough leaning over a little that I don't want to push it.
Is there a local cycle shop you can ask?
Thanks,
George
  • TonyKZ1
  • TonyKZ1's Avatar
11 Nov 2005 06:15
#7687
Hello, you might try looking for the metric sized equivalents instead, 3.25x18 & 3.50x18 = 100/90-18. Since the 100/90-18 rear can be harder to find depending on the brand you look at, I put a 110/90-18 on the rear of mine. I originally had cheng-shin himax's installed, they didn't seem to last long, about 12k miles, of course on some bikes that's very long tire life. They worked okay I guess, not real good, just okay.
I've currently got Bridgestone Spitfire's 100/90-18 & 110/90-18 on mine now. They're much better than the cheng-shins.
Tony
1997 Yamaha Seca II - mostly stock, Oxford Heaterz heated grips, a Scottoiler system. My Mileage Tracker Page
