Bike lift
- MaddMaxx
Bike lift
09 Sep 2006 03:07
Ok guys, I just bought a really nice bike jack. It has two removable/adjustable "rungs" and will lift a 1500 load up to 24 inches. Problem is the way the KZ pipes are run. I can either lift it by the pipes or I can rig a center piece and lift it by the engine block. Now I could be wrong, but it doesnt seem to be a good idea to lift the weight of this beast by letting it rest on the exhaust or the bottom of the motor, any thoughts?
- Mcdroid
- Gone Kwackers
Re: Bike lift
09 Sep 2006 04:55
MaddMaxx...you will crush your pipes if the jack supports the bike via the pipes...many folks use the engine to support the bike and that shouldn't be a problem. I usually remove the pipes to lift the bike (I have a Craftsman motorcycle lift) but each time you remove the pipes you may have to replace the exhaust gaskets or anneal them, at a minimum.
Post edited by: Mcdroid, at: 2006/09/09 07:56
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- MaddMaxx
Re: Bike lift
09 Sep 2006 05:10
I bought the yellow Craftsman with the optional atv adapter. I have been doing dangerous stuff like giving it a 4X4 in the center to keep from pulling the exhaust. I will stop that. Thanks.
Post edited by: MaddMaxx, at: 2006/09/09 08:13
- donthekawguy
Re: Bike lift
09 Sep 2006 06:04
Are you putting a strap around the frame when you lift it? You should and if you do the bike should-should stay up. :ohmy:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- MaddMaxx
Re: Bike lift
10 Sep 2006 00:14
Yeah but my concern was for the exhaust and motor itself. I just thought the weight was too great for either.
- barney
Re: Bike lift
10 Sep 2006 09:01
Yea I had the same problem with my new lift. I got a couple of peices of aluminum barstock(hardwood will work)and used hoseclamps to secure the aluminum spacers to the framerails then just jacked off of the spacers.I dont recommend you jack off of the oil pan or the exhaust.
- kawtoy
Re: Bike lift
10 Sep 2006 13:07
barney wrote:
Hmmmmmmmmmmmmmmmmm :whistle: :huh: :sick: :woohoo:
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- barney
- superjohn
Re: Bike lift
02 Jun 2007 21:16
Hey Barney,
i realize this is pretty old post but...
i just tried my new craftsman mc/atv lift today and found that i'm the last to learn about the exhaust pipe issue with this lift. my own fault, i should have checked the archives before i bought it...
i happened across your old post about securing bar stock to the frame with hose clamps and wondered if you could offer any additional info. size/lenght of the bar stock? where to attach them to the frame etc.
i'd hate to have to get rid of the lift. it seems like a nice unit...
any info you (or anyone for that matter) has would be greatly appreciated.
(novice rider, only my second summer, still pretty ignorant about a lot of this stuff etc.)
oh, '79 kz1000st for reference. thanks.
john
john
- zmaniscalco
- KZ250LTD
Last edit: 28 Aug 2009 22:53 by KZ250LTD.
