79 LTD 1000 Rake Question
  • larrycavan
  • larrycavan's Avatar Topic Author
  • Visitor
06 Sep 2006 17:21
#74952
The 77-80 LTD 1000 have a listed castor angle of 64 degrees with 16" rear wheel and 19" front wheel.
The standard KZ has a 27 degree angle with 18" rear, 19" front.
All these years I thought the difference in angle was achieved from the smaller back wheel changing the angle of the steering stem in relation to the ground. I did not think there was a difference in the actual frames other than different tabs welded here and there. I now believe the frames are actually different.
Tonight, I setup my 79 LTD 1000 frame on blocks, set it to 9" off the floor and leveled it. I put an angle finder on the steering stem and sure enough, it read 64 degrees.
Does anyone know for sure about the frames?
  • steell
  • steell's Avatar
Re: 79 LTD 1000 Rake Question
06 Sep 2006 17:36
#74954
Can't help you any on the frame info, but I can tell you that during my research on converting from a 16" rear to a 18" rear I discovered there is an average of 3/8" difference in diameter between a 130/90/16 and a 120/90/18.
10 Sep 2006 16:51
#75736
I am looking at my ltd owners manual and it show's the frame to be at 64 degree castor and 90mm(3.5 in)trail. B)
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
10 Sep 2006 18:28
#75774
64 degrees from horizontal is 26 degrees from vertical.
