Air Fork Pressure
  • madderkaw
  • madderkaw's Avatar Topic Author
Air Fork Pressure
06 Sep 2006 14:02
#74905
I recently purchased (the nicest thing I have ever gotten from cheese-bay, by the way) a pair of air adjustable forks from an 80 750 LTD. I plan on installing them on my 80 650 LTD over the winter. While looking through the KZR spec sheets on these bikes, I did not see a recommended air pressure, or a range of pressures that could be used. I also noticed that the stoke of the 750 fork is almost double (100mm vs. 180mm). is that correct? And if so, could it be a problem? I figured a fork from a heavier bike would ride a little firmer, which is what I was looking for. Since I added the double disc setup, my front end has been a little soft on the brakes and I was hoping that this fork would be the solution. Any help or suggestions would be greatly appreciated.
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: Air Fork Pressure
06 Sep 2006 15:11
#74920
Don't know KZ but I run 12lb in my FT500. With your fatter tubes start at 8lb and see how it feels. Mine are skinny 37mm. Make sure nothing hits at full travel.
-Duck
  • cnyl
  • cnyl's Avatar
06 Sep 2006 15:43
#74929
I don't remember but I think my 82 GPz750 is 10lbs max.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
  • steell
  • steell's Avatar
06 Sep 2006 16:30
#74934
I think both bikes were real close to the same weight :)
Heavier oil in the forks might have helped (and still may be needed).
  • Jim N
  • Jim N's Avatar
08 Sep 2006 10:03
#75292
8-14 lbs. I just flushed my fluid and loaded mine up to 12 lbs, since I'm a big guy. Just about right for me, a little stiff, but it dives a lot less now.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
08 Sep 2006 10:38 - 03 Dec 2008 17:17
#75296
del
Last edit: 03 Dec 2008 17:17 by JMKZHI.
