pivot arm shaft question
  • Clifftex
  • Clifftex's Avatar Topic Author
05 Sep 2006 14:18
#74681
I'm a newbie. I am modifying a KZ650, replacing the swing arm with a different one. The original shaft size is #16 in diameter, 306mm long. My new swing arm requires a #14, 306 to 310 mm long. Does anyone know a bike that has that size shaft? I've been having a heck of a time finding it. All the sites I've looked at list the shafts by bike only, not length and diameter.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: pivot arm shaft question
05 Sep 2006 19:46
#74757
JUST WONDERING IF A MACHINE SHOP COULD TURN YOUR BOLT DOWN TO 14 AND RE THREAD IT.You would still need to fill the space in the frames bolt hole form the 16mm bolt hole to accept the 14mm bolt.You could have them leave it 16mm near the bolt head then you would only have to shim one end.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Clifftex
06 Sep 2006 05:06
#74798
good idea. I think I may have to do that. Thanks.
