Would this work for wider wheels?
  • Samwell
  • Samwell's Avatar Topic Author
05 Sep 2006 03:41
#74569
I've spent a lot of time staring at the jumble of parts that was (and hopefully will be again) my kz1000A2. The rims are a little chewed up from neglect, minor accidents, and probably less than expert tire changes. Would it be reasonable to change just the rim (leave the axle,hub etc stock). I know this would require re-lacing the wheel, but then I'd have nice new stainless spokes too.
I found this link: www.buchananspokes.com/Akront.htm
They have an 18" rim that's 3.5" Just a little wider than stock.
Or is this just asking for trouble?
Sam
  • MaddMaxx
  • MaddMaxx's Avatar
Re: Would this work for wider wheels?
05 Sep 2006 04:12
#74572
Man that is a good question. I would like to go wider as well with my kz1000C3. It was a stock cop cycle in March when I got it. Now its a bobber and I find something to change almost everyday. I have completely neglected my HD over it. I am in the thought of putting a larger tire in the back. It was standard 18s front and back, now a 16 on back and a 19 front. I need spacer help for the front. If you find a way to use the hub post it please.
  • donthekawguy
  • donthekawguy's Avatar
05 Sep 2006 05:46
#74590
I'm going through the same thing right now. I just got a 18 in with a 5 in rim. I'm going to have Les build me a swingarm for it. It will only be used at the drags but it should work out.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • wireman
  • wireman's Avatar
05 Sep 2006 06:16
#74595
18x3.5 is common swap for rear,no problem.;)
