FRONT FORK SWAP
- kawadruida
FRONT FORK SWAP
04 Sep 2006 09:21
Hey:
I´ve ran into a nice 1992 Ninja 600R fork, complete with lower and upper holders, wheel, brakes, fender, handlebars, front master cylinder, etc. even the insruments panel...
All parts come from a bike that was hit sideways (in the rear) by a car, ended really beaten and actually twisted, but the front end is still intact and the scrapyard will sell it for a real low price.
Is it difficult to fit it in my ´84 Gpz550? Does this kind of job involves major mofifications at the front sections of the frame? Is the supposed improvement in suspension, comfort, braking and handling really worth the pain and money?
Cheers.
Cheers.
- GPZSCOTT
Re: FRONT FORK SWAP
05 Sep 2006 17:54
I put the same forks on my `84GPZ 750.They were the same size +even used same bearings!I don`t know if the 550 is same size as 750.Do like I did+put both triple trees side by side+take measurements.Should still be a real easy swap.I`m putting the ZX6 swingarm on my bike now.
My Bikes:1981 KZ750H-1 LTD
1984 ZX750A-2 (GPz750) with `92 ZX6 suspension
1984 KZ750B LTD
Plus enough parts to build another complete GPz750
1984 KZ750B LTD
- kawadruida
Re: FRONT FORK SWAP
06 Sep 2006 12:15
Thanks for your input GPZScott!
Judging from the pic, I can say that the 750 is the same bike as the 550, except for the extra 200 cc.
Anyway, I'll follow your advice about measuring everything first just to be sure...
BTW, is that a Supertrapp on your bike and are those front rotors the original ones from the Ninja? They look bigger to me, I think that your fork is from a 1992 Ninja ZX-6 (ZX600-D3) and the one I´m talking about is from a 1992 Ninja 600R (ZX600-C5), which are indeed very different bikes.
Anyway, let´s see what happens. I´ll go to the scrapyard to take some measures and pics, will post them as soon as I can.
Cheers
Cheers
- medic24
- kawadruida
Re: FRONT FORK SWAP
09 Sep 2006 08:51
Sure thing, my ´84 Gpz550 (ZX550A1) has an 18 inch front wheel, with the complete fork swap it will go down to a modern 16 inch front wheel.
Your bike (KZ550H2 Gpz) comes with the older 19 inch front wheel, a more dramatic decrease in size.
I think a smaller front wheel gives the bike quicker steering, right?
- GPZSCOTT
Re: FRONT FORK SWAP
09 Sep 2006 17:02
Yes,they`re rotors that came with front end.The donor bike was a `92 ZX6 which came with 17" wheels.I learned EVERYTHING about my bikes from KZrider.The archives have a ton of great info.
1984 KZ750B LTD
1984 KZ750B LTD
- medic24
Re: FRONT FORK SWAP
09 Sep 2006 21:00
now you guys ARE killing me..... I have two unused zx600R Ninja front ends lying in my garage... maybe one should go onto "Mad Max" the KZ550 project? Just concerned about the geometry change. AND the following change that might be needed in the rear. hehehehe
- kawadruida
Re: FRONT FORK SWAP
13 Sep 2006 15:08
GpzScott, I thought that both the ´92 Ninja 600R and the ´92 ZX6 had 16" front wheels, but apparently the 600R comes with a 16" wheel and the ZX6 with the 17" one...
Medic24: In your place, I´ll follow GpzScott´s advice: measure things carefully and calculate the risks and pros and cons. Personally, I think that the little geometry change will make your KZ550 a quicker steering bike and a better looking one too. But I´m no expert in chassis geometry though...
:whistle:
Cheers
:whistle:
Cheers
- kawadruida
Re: FRONT FORK SWAP
13 Sep 2006 15:08
:whistle:
Cheers
:whistle:
Cheers
