How reliable is the drum brake shoe wear indicator?
  • savedrider
  • savedrider's Avatar Topic Author
  • 1975 Z1-B 900
09 Nov 2005 18:11
#7422
Can this be trusted or is it better to pull the shoes and measure with a caliper?
Thanks
Get right or get left! <*{{{><
  • Salvy
  • Salvy's Avatar
Re: How reliable is the drum brake shoe wear indicator?
09 Nov 2005 18:40
#7428
In theory it's pretty darn good. A direct link to the brake shoes.
Problem is that it has to be set properly when the brake shoes are installed. You can put that needle anywhere when the rear hub is disassembled.
So - it depends on the reliability of whomever last serviced the brakes.
-S
  • jenshhj
  • jenshhj's Avatar
09 Nov 2005 18:52
#7432
Given a couple of decades of use and previous owners' disassemblies - consider the indicator to be useless - have a look yourself!
  • RonKZ650
  • RonKZ650's Avatar
09 Nov 2005 19:21
#7435
Like salvy said, it's a very good indicator if it hasn't been fooled with on its positioning. Thing is, it really is not that necessary to even have, since rear tires wear out at the rate of one every 5-10,000 miles just look at the brakes every time you change tires. The pads last a good long time, normally well over 60,000 miles even with a lot of stop/go. At least my experience anyway.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
10 Nov 2005 17:53
#7622
As the needle can be repositioned to the wrong place, it is an unreliable method of gauging brake wear. I know of one person who move the needle to get the bike to go through an inspection. The bike was previously failed as the needle showed full wear...
  • savedrider
  • 1975 Z1-B 900
10 Nov 2005 18:03
#7624
Will the shoes give you any sign of being close to worn out such as screeching? Or maybe it's too late and you are scoring the drum by that time.
  • Jeff.Saunders
  • Vendor
  • Vendor
10 Nov 2005 19:09
#7631
I've never taken any down that far - in all the bikes I've seen, I've never had one where the shoes are totally gone...
  • savedrider
  • 1975 Z1-B 900
10 Nov 2005 19:41
#7638
Wow, it sounds like they really do last a long time. I'm not going to worry much about mine then until the next time I have the wheel off.
Thanks
Post edited by: savedrider, at: 2005/11/10 22:42
  • The Milkman
  • The Milkman's Avatar
10 Nov 2005 19:53
#7641
For the little time it takes to do a tear down aan physically look at them so you know for sure their condition, just the peace of mind would be worth it. We all try to get our bikes to run faster seems to me we would want them to slow down just as fast and know we are safe.
Ride safe,
Les
