<<<>>>Front view -->> 650CSR
  • JMKZHI
  • JMKZHI's Avatar Topic Author
31 Aug 2006 14:48 - 22 Feb 2013 11:17
#73710
Last edit: 22 Feb 2013 11:17 by JMKZHI.
  • JMKZHI
Re: .
01 Sep 2006 07:10 - 22 Feb 2013 11:17
#73848
  • Rickman
  • Rickman's Avatar
Re: Front wheel not centered between the Forks
01 Sep 2006 11:56
#73892
heh you know how it goes, take it apart and see; make sure it looks like the parts diagram on kawasaki.com.
Probably needs grease anyway, right?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
  • JMKZHI
Re: .
01 Sep 2006 12:42 - 22 Feb 2013 11:17
#73906
  • JMKZHI
Re: .
01 Sep 2006 12:44 - 22 Feb 2013 11:18
#73907
Last edit: 22 Feb 2013 11:18 by JMKZHI.
  • timber
  • timber's Avatar
02 Sep 2006 20:00
#74177
funny that you say this cuz i noticed the same thing on mine today. now i just put it all together so i guess it all comes off again also. i will share what i find, please keep us updated on what you find.
  • JMKZHI
Re: .
02 Sep 2006 20:58 - 22 Feb 2013 11:18
#74188
  • MaddMaxx
  • MaddMaxx's Avatar
03 Sep 2006 04:33
#74214
Got the same problem, and it has kept me from riding it. Mine is due to the guy before me changed the 18 inch mag to a 19 inch mag. Seems to be ok except for the offset which incidentally keeps the discs from lining up as well. There is a quarter to a half inch play in the axle. Need a spacer, anyone know where I can get it?
