<<<>>>>Fo​rk holder tools various
  • JMKZHI
  • JMKZHI's Avatar Topic Author
28 Aug 2006 19:49 - 22 Feb 2013 11:16
#73097
Last edit: 22 Feb 2013 11:16 by JMKZHI.
  • JMKZHI
Re: <<<>>>>Fork holder tool tip
28 Aug 2006 20:26 - 22 Feb 2013 11:15
#73112
Last edit: 22 Feb 2013 11:15 by JMKZHI.
  • heartless
  • heartless's Avatar
Re: Special Fork Tool
31 Aug 2006 04:40
#73608
those tools are for one purpose only - to hold the inner tube still while removing the allen bolt from the bottom. In most cases, if the inner tube is not held with one of those tools (or a homemade version of those tools) it will just turn with the allen bolt. The 4 in your pic are just different versions of the same basic tool.
not having a 650CSR I cant really comment on the "little plastic thingies" of which you speak. hopefully someone else can/will chime in on that subject.
  • JMKZHI
Re: .
31 Aug 2006 07:32 - 22 Feb 2013 11:14
#73622
Last edit: 22 Feb 2013 11:14 by JMKZHI.
