Sticky steering
- Papa Uff Da
Sticky steering
28 Aug 2006 14:32
Today on my way home. While making a right turn from a stop. My handlebars stuck for just a fraction of a second. and was repeatable a few more times at speeds from 0 - 20. What do I neeed to do/check?
- hwms
Re: Sticky steering
28 Aug 2006 15:09
Bearings. Lubricate and adjust or replace with tapered bearings.
- medic24
Re: Sticky steering
28 Aug 2006 15:36
JUst in the process of replacing my KZ550 head bearings with tapered ones, so far they are easy and smooooth as silk!
- oldcoldankles
Re: Sticky steering
28 Aug 2006 16:37
My KZ550 used to do that and I thought it was the steering stem bearings, but after rerouting the clutch cable to eliminate it binding the problem was solved.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- Duck
- e vica na i sau na ga
Re: Sticky steering
29 Aug 2006 03:20
The fork lock may be stuck in it's 'spring loaded, ready to engage' position. Nasty, gummed up, and rusty but ready to pop into place any moment.
-Duck
-Duck
- Biquetoast
- King Jeremy The Wicked
Re: Sticky steering
29 Aug 2006 05:11
Papa Uff Da wrote:
All the others have posted great things to look at, but I would just say to get it up on the centerstand (if you have one), jack up the front, and try to duplicate the stickiness... and watch and see if anything is obvious first... before you tear it all apart.
Whoa - that had to be a pretty scary feeling.Today on my way home. While making a right turn from a stop. My handlebars stuck for just a fraction of a second. and was repeatable a few more times at speeds from 0 - 20. What do I neeed to do/check?
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- Papa Uff Da
Re: Sticky steering
29 Aug 2006 09:01
Yes it was a bit woriesome. Today I am going to replicate the issue. Hopefully it will be something simple. Thank you all for your input I greatly appreciate it.
