Lowering the Bike
- 78kz1
Lowering the Bike
25 Aug 2006 21:05
Ok, I know this has been asked a bunch, but I'd like the latest info on lowering my bike - 1978 KZ1000, chain drive. If I go the LTD wheels, will most years around 1978 fit? I've also seen something about using sportser shocks instead of changing the wheels? Whats the story with that? As far as the front end goes, is it a big deal to slide the forks up in the tree? I looked at that, and can't really tell what is being moved. Help me out guys, i'm another vertically challenged KZ owner:)
Post edited by: 78kz1, at: 2006/08/26 00:06
- wireman
Re: Lowering the Bike
25 Aug 2006 21:18
you can lower rear with short shocks raising fork tubes up in triple trees will lower front,but dont lower front more than rear of bike.
- vanlagan
26 Aug 2006 14:29
I'll be watching this thread closely. I have an 81 KZ750 that I need to bring down some for my vertically challenged wife. I'd like to find a seat for it and try shaving it down a few inches. The seat that is on it is original and perfect so I'd like to find another to chop down incase it doen't work out well.
- 77KZ650
26 Aug 2006 18:29
after you lower the rear of the bike (dont lower front more than rear or it wont be stable at high speed) you just have to loosen the 2 bolts in the triple trees (2 for each side/fork) very slowly, and gravity will do the work for you. let the forks slide up to the desired position, and tighten the bolts again. just measure the amount sticking up past the top triple and make sure its the same on each side.
as to shaving the seat down, check out this
07 MDP Rookie of the Year
- donthekawguy
26 Aug 2006 18:31
On my 78 1000 I have a set of lowering tubes that go inside the forks and the brackets that move the bottom of the shock back for the rear. When you go down a couple of inches, you will need to watch out for exhaust clearence and you will have to shorten your kickstand. BTW I'm switching back to spoke wheels and will need to get rid of my ltd mags. If you can hold out for a month or so they are yours for shipping. Also if you need a dual front disc line splitter I need a single so how about a trade?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- 78kz1
27 Aug 2006 07:38
I'd be interested in the trade, stay in touch and let me know when you are ready.
- donthekawguy
27 Aug 2006 12:04
Cool. I already won the rear wheel off ebay and I'm bidding on a front today. The rear wheel might take a bit longer as I need a new swingarm. The wheels might cost a bunch to ship but they are in good shape. They are painted kinda of a goldish color and I can also send the rear caliper and M/C and a front caliper with a Russel braided line. I'm going to be running a single front disc and no rear brake so your welcome to all the parts I'm taking off.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- wireman
27 Aug 2006 15:15
donthekawguy wrote:
:S :dry: :huh:
Kamikaze,japanese suicide plane or motorcycle the motorcycle version was loaded with fuel and only front brakes,riders were volunteers ....:S
Post edited by: wireman, at: 2006/08/27 18:26
no rear brake?:sick: :ohmy: :blink:Cool. I already won the rear wheel off ebay and I'm bidding on a front today. The rear wheel might take a bit longer as I need a new swingarm. The wheels might cost a bunch to ship but they are in good shape. They are painted kinda of a goldish color and I can also send the rear caliper and M/C and a front caliper with a Russel braided line. I'm going to be running a single front disc and no rear brake so your welcome to all the parts I'm taking off.
- donthekawguy
29 Aug 2006 05:49
The track up here has a reallllllly long shut down area so I won't need the rear. The wheel I just won off ebay has a drum brake that is stripped down so if I need to I'll put it back together or buy a new hub for it. I'll give it a shot and see what happens. i don't plan on being in the 9's for another year so it should be ok for next year. I hope! :woohoo:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- wireman
- thetemples
29 Aug 2006 18:12
Mine was lowered by drilling new holes in the calfab swing arm and moving the rear shock mount back.
The front fork srings were cut (internally)
Pic
kzrider.com/index.php?option=com_ponygal...&func=detail&id=1429
Pic
- donthekawguy
29 Aug 2006 18:34
wireman wrote:
For the Friday night races they really don't look at the bikes too much. They are more concerned about having leathers and boots more than anything. If I have to I could rig it up to make it look like they work.will you pass tech with no rear brake?:whistle:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
