Question on air shocks
- ScottZ
25 Aug 2006 06:48
My 82 Spectre owners manual (Thanks Mcdroid!) mentions that you shouldn't use a tire gauge to check the pressure in the shocks because you lose air when you connect it. What should I check it with? The manual says to use the one that came in the tool kit, but it is missing from mine. Any ideas?
- oldcoldankles
Re: Question on air shocks
25 Aug 2006 07:27
I usually borrow my riding buddy's Harley pump and gauge. Designed to allow precise control for air volume, it features a "micro bleed" valve. You can frequently find them for around $20 -$30 on eBay under Harley p/n 54630-03A. I think they are made by Progressive Suspension and you see 30 and 60 psi models offered. The 30 psi pump is plenty to allow you to set the pressure at about 8½ psi or so.
Post edited by: oldcoldankles, at: 2006/08/25 10:37
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
