should I plug my tire
- 782david
22 Aug 2006 17:42
Just got home and found a small nail in the main body of the tire directly in the center. Can the hole be plugged or should I stay away from doing this? The tire is in real good shape with lots of wear left.
- btchalice
Re: should I plug my tire
22 Aug 2006 17:54
i would never plug a bike tire too much at risk
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- mykznme
22 Aug 2006 18:06
most tire plugs are rated at 70-95mph but id have to agree with alice on this one.
once bike tires are punctured thats pretty much the end of em in my book(unless tubed)
- steell
22 Aug 2006 19:12
In my opinion, a tire plug on a bike is a temporary emergency repair to get you to someplace the tire can be properly repaired.
A proper repair will consist of a patch on the inside of the tire, and I would only do that until I had the $$ to buy a new tire
Post edited by: steell, at: 2006/08/23 07:45
- Duck
- e vica na i sau na ga
23 Aug 2006 04:12
Have it hot patched on the inside.
If you're tight for $, do the dismount/mount yourself.
Index mark tire and rim.
Have it patched.
Buy a tape weight that weighes the same as the patch. Maybe a hair more.
Remount tire with index marks lined up.
Apply tape weight 180 degrees around the rim fom the hole.
IMO the hot patch is safe to use until the tire wears out.
-Duck
Post edited by: Duck, at: 2006/08/23 07:14
Have it patched.
-Duck
- 782david
23 Aug 2006 14:31
No tire or motorcycle shop would patch the tire due to safety reasons. Had to get a new one. He put on a Duro tire, anyone ever hear of that brand?
- mohawkaudio
23 Aug 2006 16:06
sounds like he just wanted to sell ya a new tire.
plugs are for emergencies (i carry a plug kit)
but the best and cheapest way to go is a tube.
did he let ya keep the old tire?
if it has alot of wear left, just buy a tube at the next tire change, and have it balanced.
as far as duro........sounds like cheap korean stuff to me, never heard of it, and i've been in the wind for 30+ years.
- steell
23 Aug 2006 19:17
I think one of the 750 twins I just bought has a pair of Duro tires on it. It's not running yet and I had never heard of then before, so I can't be of any help either.
