fork oil question
  • pstrbrc
  • pstrbrc's Avatar Topic Author
  • '81 GPz 1100 project
fork oil question
21 Aug 2006 10:18
#71355
Still working on my '81 GPz1100. I have the front wheel off to have the disks turned and such, so it's an obvious time to check/change fork oil. My Clymer doesn't specify oil weight, though. 10 weight and 15 weight seem to be the most often used, and I would guess that 10w would provide less dampening than 15w. I won't be using this for hard sport riding, mostly using it as a sport/touring bike. What should I use?
While I'm asking questions about the forks, this bike has air fittings on each fork cap. In my younger days it was pretty easy to find a balance hose for these, but I don't seem to be able to locate one. Any suggestions?
Thanks.
Bruce
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: fork oil question
21 Aug 2006 11:28
#71375
Bruce, if no one gets to you this afternoon, I have the shop manual for your bike, but it's at home...I'll post later, if necessary.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
22 Aug 2006 02:45
#71506
Bruce:
The manual specifies 10W20. As for the air fitting, I have seen them on eBay...so patience is in order...keep watching...all things appear on eBay, eventually.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • pstrbrc
22 Aug 2006 07:05
#71548
10w20? I don't find fork oil being sold in a multi-viscosity form. I find SAE5, SAE10, SAE15, SAE20, etc. Does the manual mean that I should just use an oil with a viscosity between 10 and 20? Oh, yeah, and once I figured out what to look for, I found Progressive Suspension's Air Fork Balance Kit (AFB-1) sold all over the place, including Amazon.com! I've ordered one from CruiserCustomizing.com, 'cause theye were the cheapest.
Elkhart, Kansas USA
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
22 Aug 2006 07:45
#71556
Bruce...that is what the manual states...use 10 or 15W and you'll be correct.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
26 Aug 2006 19:15
#72726
Sorry to jump in on this thread, but I am confused here also. It says in my manual (79 KZ1000 MKII) to use 10W20 but all I can find is straight weight ie: sae5, sae10, etc... Is it OK to use straight weight when multi viscosity is called for? And which weight is equivelent?
Thanks
The Kaw List:
