1000 trees & 1100 forks
  • wagonmaster69
  • wagonmaster69's Avatar Topic Author
  • 78 KZ1000A2 / 82 KZ1100 Spectre
20 Aug 2006 14:25
#71136
Dose anybody knows if the forks of a 82 KZ1100 will fit the tripple trees of a 78 KZ1000 and if so will I be able to fit my spoke rim from the 1000 on it?
  • steell
  • steell's Avatar
Re: 1000 trees & 1100 forks
20 Aug 2006 15:35
#71147
I don't think they will fit, IIRC, the 78 1000 has 36mm fork tubes, and the 1100 has at least 38mm fork tubes.
  • wireman
  • wireman's Avatar
20 Aug 2006 17:29
#71174
i think that 1100 the forks are leading axle.whats wrong with your kz forks?:whistle:
  • wagonmaster69
20 Aug 2006 20:31
#71222
the bike I just got is a single disk and i want the duel disk set up like on the 1100 front end.
will the tripple trees fit the 1000?
What I was going to do is rase the toobs up enough to put clip on on top of the trees insted rite under the top trees.
  • wireman
  • wireman's Avatar
20 Aug 2006 20:39
#71231
adding dual discs is pretty easy on your stock frontend.;)
  • wagonmaster69
20 Aug 2006 20:56
#71237
Well that settles that I was preaty sue of it but I wanted somebody with more experties.
But I guese you have to do wireman:whistle: ;)
Thanks for the input.
Now dose anybody needs a front end from a 82 KZ1100:huh:
Post edited by: wagonmaster69, at: 2006/08/20 23:57
  • btchalice
  • btchalice's Avatar
21 Aug 2006 05:06
#71274
i already have one i dont need
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • JUSTICE114
  • JUSTICE114's Avatar
23 Aug 2006 10:24
#71840
Will it fit on a 77Kz1000????? and where are you located? Ok i just reread the post. Next question is do you have the triple with it? Sorry im a lil slow today.:pinch:
Post edited by: JUSTICE114, at: 2006/08/23 13:25
  • wagonmaster69
23 Aug 2006 10:53
#71846
yes I have the whole front end trees on down and I am in Hacienda Heights that is just East of Los Angeles CA
Post edited by: wagonmaster69, at: 2006/08/23 13:54
  • JUSTICE114
23 Aug 2006 12:53
#71874
Ok guys go with me here......newbie question.........Will the 82 triple fit on my 77 frame?????? ANd if so, WM69 why dont you just swap the whole front end? :huh: Just curious.
Post edited by: JUSTICE114, at: 2006/08/23 15:55
  • wireman
  • wireman's Avatar
23 Aug 2006 13:45
#71890
just rebuild your 77 frontend,nothing wrong with the older frontends.
  • wagonmaster69
23 Aug 2006 14:22
#71898
I would change in a heart beep but if I just need to find a disk and caliper for the other side I would do that just because I like the spoke rim and the 1100 is a mag rim.
