rear wheel width ?
- 01busa
rear wheel width ?
19 Aug 2006 00:21
I have read alot on hear about rear wheel sizes stock up to 6.0 inches, and some of the problems that they incure. I am getting a D & G 8" over swingarm and would like a 5' rim setup so I can use the MT slick, is there any difference between 5' rims or will any 5' rim work?
Thanks for any help.
Post edited by: 01busa, at: 2006/08/19 03:22
- btchalice
Re: rear wheel width ?
19 Aug 2006 04:47
if the axle size is the same then you just have to make spacers to center it and align the sprockets
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- 01busa
19 Aug 2006 15:39
Thanks for the help, so I guess any rim thats 5" will work Honda, suz, kaw, Yamaha as long as the axle is the same. Could you also make bigger holes in the swingarm for bigger axle if you had to.
- btchalice
19 Aug 2006 18:44
i would assume you can if you have access to a mill to make sure its straight
