Keeping license plate on?
  • psychbiker
  • psychbiker's Avatar Topic Author
17 Aug 2006 13:47
#70338
I've tried searching the forums and Googling, but don't think I can narrow the search properly.
1981 KZ750 LTD --
How do you keep the license plate from working its way free?
I used what I thought were locking bolts, but discovered after an 80 mile ride yesterday, the plate was hanging by one bolt.
Thoughts?
  • fixer5000
  • fixer5000's Avatar
Re: Keeping license plate on?
17 Aug 2006 13:58
#70341
put a pc of foam rubber across the top of the plate...use loctite on both bolts...done deal itll never fall off...steve
1978 kz650b pretty much stock
massachusetts
  • JMKZHI
  • JMKZHI's Avatar
Re: .
17 Aug 2006 15:45 - 03 Dec 2008 18:39
#70380
del
Last edit: 03 Dec 2008 18:39 by JMKZHI.
  • ambergrismooon
  • ambergrismooon's Avatar
17 Aug 2006 16:08
#70396
Just use a dab of Silicone adhesive on the thread ends. Keeps them on until you want them off.
  • agawam
  • agawam's Avatar
17 Aug 2006 19:35
#70463
wire ties.... I have my plate bolted on but use wire ties for extra measure.. if you think your KZ vibrates the plate loose mine is a two stroke H1 and the plate stays on
  • mykznme
  • mykznme's Avatar
17 Aug 2006 20:24
#70476
find a decent graffix artist and have em paint it on.
fender eliminator to the max.(check local laws)
R.I.P. Odd Ivar
  • mikekz900
  • mikekz900's Avatar
18 Aug 2006 13:03
#70683
use a nylon locking nut, or use red loctite.
  • floridamba
  • floridamba's Avatar
19 Aug 2006 08:46
#70883
I've used about everything out there and have settled on using zip ties. Get black ones so you don't see them. I have the bolts from Z1Ent and will also wire tie to keep the plate on.
I used to have an H-1 in 1974, and found that my license plate would get some grime and smoke and oil on it.... I used a brillo pad to get the oil off and it also took off most of the painted numbers on the plate. Don't try this at home.... but it did make it harder to read.
  • loudhvx
  • loudhvx's Avatar
19 Aug 2006 10:44
#70898
Whenever I need a self-locking nut and I don't have one, I take a regular nut and squish it ever so slightly with a pair of Vise-Grips. It works good, but you will need a little practice to get the right amount of squish. If you don't have spare nuts (and who couldn't use a spare nut) I wouldn't try my method unless you are desperate and are very good at judging squish.
