HELP! Undoing Tail Modifications back to original!
  • EMNM30
  • EMNM30's Avatar Topic Author
17 Aug 2006 11:00
#70273
I will attach more photos later from underneath the rear tail to show you what I am working with. I attached one I have for now-see rear tail mod.
But I am wondering if anyone can please help me out:
I have a 1980 KZ 650 F1, & P.O. removed rear chrome fender, then welded the tail light onto the tube frame under the tail. It just kind of looks bad-the tail light is pointing down. I just got a replacement fender & light assembly for my exact bike. I have the tools available to cut the welds. I just don't know what the original should look like underneath before I cut anything to see if they removed other vital frame work to modify it to this. I do not, however, have welding equipment available if they did remove other vitals.
Which is why:
1. Could someone please take some photos underneath of their rear fender that is still in original condition with the chrome fender so I can compare to mine?
A. Would like location pic where chrome fender is bolted underneath. I have 2 spots available, but not sure if it is the front or back holes to align.
B. Not sure if just those two bolts would be sufficent with the weight of the fender and the light! Would like to know where else the fender is attached to. PLEASE?!
C. I found some original pictures, but they don't show enough detail. I see I also have to move the turn signals back onto the red light's frame.
Any other information would be appreciated, THANK YOU!.
  • mariozappa
  • mariozappa's Avatar
Re: HELP! Undoing Tail Modifications back to original!
17 Aug 2006 11:29
#70281
I believe the fender is only held on by those 2 bolts (I'll check tonight).
There is a black metal piece that attaches to the rear fender for the taillight and license plate, looks like that is what the PO welded on.
The turn signals are suppose to be on the side of tailpiece right where they are.
Make sure you remove that chain during the preflight inspection!
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • EMNM30
17 Aug 2006 12:18
#70292
great, thank you, here is the original picture I was refering to-unless it's a different year? see red arrow, is this significant to hold the chrome fender? -because I don't have it. Just came to mind- or are they just sissy bars?
Post edited by: EMNM30, at: 2006/08/17 15:23
Post edited by: EMNM30, at: 2006/08/17 15:24
Post edited by: EMNM30, at: 2006/08/17 15:26
  • Draco
  • Draco's Avatar
17 Aug 2006 12:41
#70309
Looks to be just a grab bar for the passenger to me.
I would think that the mounting points for the fender would be up under the tail section.
  • fixer5000
  • fixer5000's Avatar
17 Aug 2006 13:03
#70316
mines a 78 but ill bet theyre the same heres a few pics to peruse of the mounts...steve
1978 kz650b pretty much stock
massachusetts
  • fixer5000
17 Aug 2006 13:03
#70317
another
massachusetts
  • fixer5000
17 Aug 2006 13:04
#70318
signal mounts on frame but not to fender
massachusetts
  • fixer5000
17 Aug 2006 13:05
#70320
yes i know i know i need to polish this stuff....id rather ride it ya know??? steve
massachusetts
  • mariozappa
17 Aug 2006 13:19
#70331
Your turn signals in the advertisement look different than mine, so I may be wrong. Mine's a 77 and they are mounted like fixer's.
1977 KZ650C1
  • EMNM30
21 Aug 2006 08:11
#71317
thanks everyone for the pics! I think I can figure out how to replace the fender now with the submitted pictures. I think it will be a fall project though-I'd rather ride it for now instead of having it in pieces until I have more time to complete it in one weekend :)
  • N0NB
  • N0NB's Avatar
  • Blue handles better
21 Aug 2006 19:42
#71467
I have a '79 650B that the tail section is off of right now. I can take a pic of that if you'd like.
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
